cancel
  #1 (permalink)
Old 03-15-09, 07:20 AM
Morania's Avatar
Can one thin Gorilla Glue?
I use Nano Glue or Gorilla Glue for my models and projects. Somethimes I get to my relatively ful bottle and find that it has thickened up from non-use. I either need stronger glasses or it doesn't say on the label but, is there a way to thin it out to become more user friendly?
  #2 (permalink)
Old 03-15-09, 07:24 AM
the_tow_guy's Avatar
Not that I know of. You certainly can't use water because water's a catalyst for the poly glue.
__________________
Measure it with a micrometer; cut it with an ax.
  #3 (permalink)
Old 03-15-09, 07:30 AM
Gunguy45's Avatar
Topic Moderator
Agree..never saw anything for that..
Heres some hints that I'm pretty sure apply to that glue though.
Store it upside down, then the stuff at the bottom will harden or thicken, since thats the part exposed to the air in the bottle. Make sure the cap is on tight!
Also, I think you can store it in the fridge...just remember to take it out before you need it.
Poly glues do have a limited shelf life once opened...buy smaller bottles if you aren't going to need it often.
__________________
Vic
Firearms and Weapons Topic Mod
"Vita brevis"
  #4 (permalink)
Old 03-15-09, 07:43 AM
You're supposed to squeeze all of the air out of the bottle and then put the cap on in order to extend the shelf life after opening. I tend to buy glue in the smallest size just because it does have a limited storage life. I also write the date I opened the bottle on it somewhere with a marker and throw it out after a year.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
