Deep Well - 120'
new here, so bear with me please. well is 2", steel pipe. tank is Well-Rite, bladder. iturned on my water, nothing. went out to well pump. breaker fine. pump was running continuous. guage said 100psi.
turned off breaker. seen points were burned very bad. i replaced the switch with 30-50 switch. turned on power, and same thing. turned power off. removed prime plug, and it was full of water.
checked valve on tank, read 14 psi. got cold, as it is 2 degrees out. turned on heater in pump shed, and came inside for night.
will check more in morning. any advice , suggestions much appreciated. hope i posted enough info. thanks, Linda G.
