cancel
  #81 (permalink)
Old 06-06-09, 12:13 PM
Gunguy45's Avatar
Topic Moderator
Not sure of what you need to use...but PP probably stands for PolyPropelyene
__________________
Vic
I'm no expert, but don't tell my wife that.
  #82 (permalink)
Old 06-24-09, 10:52 AM
thanks
i only recently learned about "plastic welding" it's all good info to see here. soem question i woulda never though of.. an answer to go with 'em!! fabulous! thanks.
  #83 (permalink)
Old 10-18-09, 10:47 AM
Question plastic welding
I purchased the a plastic welder from Harbor Freight for $80.00it had temp control and internal blower, the best plastic welder they had. I tried using this thing for a week on pvc pipe, taking care of the 3 important points; cleaning, same material and rods, and temp settings, bottom line, I got a refund. Don't know if I had a bad welder or a poorly designed tool (junk). Good thing about Harbor Freight refunds are no problem.
Sears has a Urethane Supply 5600 ht model 6 airless plastic welder. I am wondering if anyone has used this welder with any degree of success.
  #84 (permalink)
Old 10-18-09, 02:50 PM
GregH's Avatar
Super Moderator
I have a similar welder and have used it with mixed success.
Some materials can not be welded and PVC pipe could be one of them and if you can weld it you need a great deal of practice to get it even half right.
What rod did you use?
The best rod is a piece of the material you are welding.
__________________
GregH...HVAC/R Tech
  #85 (permalink)
Old 10-18-09, 03:03 PM
plastic welding
I bought rods from harbor freight marked for pvc.
  #86 (permalink)
Old 11-07-09, 04:23 PM
What type of plastic is this?
Hello I was wondering if any of you can identify this plastic for me and the appropriate type of welder to duplicate what you see in the pictures. What you see in the pictures are jet logs for commercial dredges. The material is 1/2" thick. I was told by another dredger that he made some pontoons out of the same stuff that was 1" thick. He told me the material was lighter than water so it would float. Thanks -Kevin
  #87 (permalink)
Old 11-22-09, 09:14 PM
plastic welding
Quote:
Originally Posted by Daxman77 View Post
I have been welding and fabricating plastics for about 7 years. If you guys have any peticular questions, I would be happy to answer them for you.
Dax
how do you distinguish between the different types of plastics? Is there some test to tell which type of rod to use? thanks
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
