R/O drains constantly
I have a GE Smartwater R/O unit. It is draining all the time, I have to shut of the water to the unit in order to stop it. It's about 15 months old... any ideas what could be the problem?
R/O Draining
ASO is definitely the prime suspect here.
The ASO actgs on the pressure differential between untreated water and purified water. Once the pressure on the purified side meets or exceeds the influent, the ASO will close, preventing inflow of raw water.
Depending on where your ASO is located, it might be as simple as changing your prefilter. - Have you ever changed your filters ?
A clogged drain restrictor will not cause continuous flow to drain, but can cause the membrane to foul and rupture/tear.
New Member
How long has this RO been in service without a filter change? If it has been a long time then a filter and membrane change are probably needed and you'll want to sanitize the RO.
Automatic Shut Off
Automatic Shut Off
Update--I sanitized the R/O system according to the owners manual. Changed both filters and the membrane...she still keeps draining. If I turn the valve off then back on it won't spontaneously drain, but as soon as a run some water from the R/O faucet the draining begins again.
Not sure where to go from here... there doesn't seem to be anything else down there that I can see could be causing this.. Any ideas gang??
thanks
thanks
Greg and Gang,
Ordered and installed the ASO--Still the same. She keeps draining as soon as I turn of the supply valve. Not sure where to go from here, other than to the supermarket for some spring water. Any ideas??
New Member
If the membrane isn't fully seated in the housing water will continue to run to drain.
R/O Draining
Have you confirmed that your piping connections are correct (IN/OUT/DRAIN) ?
Have you tried running it with the storage tank turned off ?
What is your inlet pressure ?
In/Out/Drain is correct... I did not touch any of that plumbing. How do I run with the tank "off"? While playing with the system I removed the tube that runs to the tank and can confirm there is PLENTY of pressure running to the tank. Funny thing is the tank doesn't fill??? Maybe that is what is wrong...maybe not
If the tank is not filling then it has too much air in it.....the R/O may continue to run because it's not building any backpressure from the tank being filled......did you replace ANY of the tubing?
Didn't change any tubing but removed the tube to the tank for a few seconds and took a nice bath because of it. I let the system run for about a 1/2 hour and she steadily sent water to the drain however the tank filled a bit, enough so I can get water from the faucet, but the draining never ceases..
You didn't let it run long enough for the tank to fill. The system will send water to BOTH the drain, and the tank while it is making filtered water. This is NORMAL. Try letting it run for 3 to 4 hours, and perhaps the tank will fill, the ASO will kick in, and the flow of water will stop. And yes, if you turn on the filtered-water faucet, draining will begin again, while the unit fills the tank, again. All sounds quite normal to me. While you're at it, check the pressure on your tank with a standard tire pressure gauge. I think it's supposed to be around 5 - 7 psi. This provides enough force to cause the water to flow out the faucet. If it's too high, the tank won't completely fill.
I did what you suggested. I let her run, she drains and drains... Every once in a while it will shut off, then as soon as you use some of the water from the system it's start the continuous drain once again.
See how long it takes for the ASO to shut the flow down.
I would expect no more than 15 seconds for that system.
What is your inlet water pressure ?
#22
New Member
You should have checked the tank pressure early in your troubleshooting...
Use a low pressure air gauge on the valve on the tank to check the pressure. It's low volume so you can lose the air quickly. If you get ANY water out of the air valve you have a ruptured tank bladder.
Shut off the water supply to the RO and open the RO faucet to empty the tank. Remove the tank and hold it over the sink to make sure it is empty.
With the tank empty there should be between 4-7 lbs pressure. Adjust the pressure as necessary using a bicycle pump. Be very carefull if you try to use a compressor... small volume and easy to pop a membrane. Replace the tank and hook it back up. Turn on the water supply to the RO and it will begin filling the tank and running the waste water to drain. When the tank is full the RO should shut off.
If that doesn't resolve the problem then go back to square one and triple check everything you did.
Check all the connections and make sure the membrane is fully seated in it's housing.
#23
http://products.geappliances.com/Pro...emid=003675345
Page 7 shows the tank shutoff valve operation.
Inlet pressure is your house water pressure. Use a pressure gauge and connect it to a hose bib or at your laundry box.
I like RO's to run at around 75psi, since that provides performance as close as possible to test spec.
The lower the inlet pressure, the slower it will produce water.
If the inlet pressure drops below 40psi, some RO's will fail to even produce product water at all.
#24
Hi Guys--As suggested I let her run.. eventually she did shut down. When I use the system it starts draining again but only for about a 1/2 minute. Guess I just needed to be more patient... Sorry to waste everyone's time.
