| Water Heaters Natural & Propane Gas, Oil, Electric Tank & Tank-less Units. Installations, Repairs, Maintenance, Services and Technical Advice |  11-19-07, 12:56 PM | | Member | | Join Date: Nov 2007 Posts: 3 | | | Help troubleshooting a 40gal. Whirlpool water heater I have a 2002 40gal. whirlpool water heater. I've replaced the thermocup 3 months ago because that was the problem. Yesterday, no hot water! Thinking it was the thermocup again i replaced it again, but it still doesn't work. I need help troubleshooting this one. Thanks, TH |  11-19-07, 04:44 PM | | Member | | Join Date: Oct 2006 Location: Wilmington Posts: 3,566 | | | Please explain further, does the pilot go out?? Or just no temp control?? If the pilot goes out, could be poor alignment of the flame to the thermocouple, a down draft blowing out the pilot, etc. So it is not necessarily the thermocouple. |  11-19-07, 06:41 PM | | Member | | Join Date: Nov 2004 Location: CA Posts: 1,897 | | If your water heater is made after July of 2003, there are some potential issues involving that thermocouple and other aspects of that WH. See class action suit: http://www.waterheatersettlement.com/ All water heaters of the new "FVIR" type are sensitive to proper combustion air supply, etc. |  11-20-07, 10:42 AM | | Member | | Join Date: Oct 2005 Location: Texas Posts: 1,030 | | | It's a low end heater that's about 6 years old. It's not worth spending more than a few dollars on it. Please be more descriptive about your problem. If it can easily be fixed someone here will tell you how. |  11-20-07, 01:16 PM | | Member | | Join Date: Nov 2007 Posts: 3 | | | Help troubleshooting a 40gal. Whirlpool water heater Sorry if i slack on terms and details. I can see the pilot light lit but it's just night igniting and no i had no water leaks. Has 594tough or anyone followed up with what he has sent me about : See class action suit: http://www.waterheatersettlement.com/ Thanks for all the input so far. TH |  11-20-07, 06:54 PM | | Member | | Join Date: Nov 2004 Location: CA Posts: 1,897 | | | Can you light the pilot by sticking a match in through the door at the bottom? If so, your unit it a little older. The FVIR ( subject of suit) has a sealed chamber, and the pilot is lit with the push-button sparker. |  11-21-07, 07:30 AM | | Member | | Join Date: Oct 2005 Location: Texas Posts: 1,030 | | | So the pilot is burning and won't kick on the main burner? Be sure the knob on top of the control is set to "on" and turn up the temperature control. If this doesn't work you likely have a bad gas control valve. | | Thread Tools | | | | Display Modes | Linear Mode | Posting Rules | You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 05:34 AM. | Sign up for our FREE newsletter! Find Qualified Local Contractors Sponsored Ads |
