cancel
Go Back   DoItYourself.com Community Forums > Interior Home Improvement Center > Walls and Ceilings
Walls and Ceilings Procedures, tools, materials for adding or removing ceilings or walls, hanging sheet rock, drywall, installing suspended ceilings.
Thread Tools Display Modes
  #1 (permalink)
Old 11-02-09, 07:55 PM
Drywalling trusses on 4' centers
Hello all, I am looking at purchasing an acreage with a shop that is not finished inside and I would like to do so, the one thing I can't figure out is how would I drywall the trusses so I can insulate it when the trusses are on 4' centers , the walls are 2x6 on 2' centers , and the building is finished with tin.
  #2 (permalink)
Old 11-02-09, 08:25 PM
XSleeper's Avatar
You would install framing between your rafters (perpendicular to them), at a minimum of 24" oc, and use 5/8 sheetrock on ceilings. It would probably be a good idea to verify the weight rating of the trusses, since the bottom chord "may" not have been engineered with the weight of a ceiling in mind.
  #3 (permalink)
Old 11-03-09, 09:37 AM
Shed Ceiling
Go to a drywall supply company and ask about DWC. (direct wall channel) What you would want is 20 Gauge. These come in 12' lengths and you can screw them on the bottom chord of your existing framing. Be sure to get 20 gauge as 25 gauge isn't good for spanning 4'.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
