cancel
Go Back   DoItYourself.com Community Forums > Interior Home Decorating and Design Center > Wallpaper and Wallcoverings
Wallpaper and Wallcoverings Selection, surface preparation, installation, tools, techniques, repair & removal
Closed Thread
Thread Tools Display Modes
  #1 (permalink)
Old 12-31-02, 01:45 PM
Members
Arrow Wallpaper FAQ, please read before posting
This section contains answers to frequently asked wallpaper questions. It is meant by no means to be the quick answer to your problems, only an immediate resource for many common problems.
If you need additional advice or clarification of the advice given on this page, please post a http://forum.doityourself.com/newthread.php so we may assist you better.
Please state type of wallpaper, plaster or drywall, amount/type of paint/primer if know, and any other details that may be important.
Can I wallpaper over my existing wallpaper?
Can I wallpaper over paneling/brick or other rough surface?
Can I paint over my wallpaper?
It depends on the type, style, and condition of your existing wallpaper. I will deal with the two types:
Non-coated Wallpaper:
Wallpaper without vinyl coating is the only wallpaper that can guarantee success. True "paper-papers" are generally high end products or products that are made overseas.
Homeowners can tell if it's a true paper by using a sponge. Wet an inconspicuous area, if there is a darkening throughout the entire surface, there is no vinyl coating. You may also be able to flake off or rub out surface inks too. With coated papers, the opposite results are to be expected.
Another consideration is strikethrough. This is a condition where the original paper's inks or pattern will appear through the new, finish paper. Bleeding of inks may also occur. Both of these errors may take hours to months for the symptoms to show up. Test hangings can assist in determining if either of these will be a problem, but as they can manifest over time, aren't an exact indication.
If you feel there will be no strikethrough or bleeding issues, hang your new paper. Otherwise, perform the same steps as if you were painting your wallpaper.
Vinyl-coated Wallpaper:
You must make every effort to remove the wallpaper first. The reason for this is based on the principle of adhesion. Wallpaper adhesives stick best on porous surfaces. Coated papers have zero porosity. Ergo, the paper doesn't have the same bonding capabilities as it would over a properly prepared surface. The other end of the spectrum holds true as well. Paper applied to un-prepped drywall has too much adhesion, therefore causing damage upon removal.
There is another issue that recently has become a major topic. That concerns mold and mildew. Imagine the mold/mildew invitation when you encapsulate wet adhesive between two layers of non-breathable vinyl. Aside from the lack of adhesion, you also created the ideal environment for mold.
If your vinyl wallpaper is causing excessive damage during removal you should perform the same type of prep that you would for painting wallpaper prior to re-papering.
All types of Wallpaper:
Try to engineer the room so that the seams do not fall on top of old seams. Never paper over existing wallpaper that is not firmly adhering to the wall surface.
Preparation: Remove all nails or other protruding objects. For textured surfaces, "knock down" any high points. For paneling, now is the time to ensure that the paneling is secure by adding additional nails. For slick surfaces/paneling, wash with TSP (TriSodium Phosphate) or equivalent grease cutting cleaner.
Now, you can hang bridging material. This is a thick, blank wallpaper designed for irregular surfaces. Once hung, this will "bridge" the grooves in paneling or other unusual surface allowing for the ultimate application of wallpaper or it can even be painted.
Alternate/additional advice: The application of joint compound to the grooves of paneling is an additional precaution when using bridging material. Some wallpaper installers use the "joint compound, then primer" technique instead of bridging material.
For ceramic tile or other slick/glossy surface, sand the surface with 200-400 grit sandpaper followed by rinsing with TSP. Apply a prep coat and then hang your bridging material. Examples of prep coats are Roman's R-35, Zinsser's Z-54, California Paint's Prep 'n Size, Golden Harvest's BITE, Muralo's Adhesium, Duron's Tack Prep, and Benjamin Moore's Wall-Grip.
You may obtain bridging material at most home improvement stores. You may find out more by visiting the following manufacturers online:
http://www.wallliner.com
Wallcoverings
http://www.flexiwall.com
http://www.hollingsworth-vose.com
Hollingsworth & Vose
Imperial Home Decor Group
http://www.ihdg.com
Sincol of America
http://www.sincolofamerical.com
Specification Chemicals Inc.
http://spec-chem.com
How do I paint over my wallpaper?
The best route is to use proper wallpaper stripping techniques first. Sometimes painting over wallpaper is preferred. Where wallpaper is adhered to unprepared drywall, this can be the only way to go.
Before deciding to paint over wallpaper, you should always attempt to strip the existing paper first. If after a valid, dedicated attempt at paper removal, it either causes wall damage or just refuses to come off, then you may take the steps for painting. This decision should not be taken lightly!
Wallpaper stripping over a properly prepared surface is actually easy to do. Stripping painted over wallpaper can be the worst case scenario and will cause you or the future homeowner problems.
Preparation is the key to painting over wallpaper. Remove any loose paper areas first. Then apply joint compound to any nail holes, seam areas, or other damaged spots. Sand these areas smooth after proper curing time. The more time you spend filling holes, patching, smoothing, and sanding, the better your end result will be.
Once you are finished your prep, close your eyes and rub your hand over the entire wall surface. Your hand will tell you where the errors are better than your eye. Without valiant efforts at preparation, it will look just like you painted over wallpaper.
Then apply a good quality primer/sealer such as Scotch Paint's Draw-Tite, Zinsser's Gardz, Roman's Liquid Drywall, Seal-Krete's waterproofing sealer, or Sherwin Williams' PrepRite Drywall Conditioner over the entire surface. Now your wall is 100% ready for paint or additional wallpaper.
How do I strip wallpaper?
The materials and techniques discussed, work on most types of wallpaper. Certain wallpapers require specialized techniques and may require professional assistance.
Wallpaper Stripping Technique
Start by stripping the outer face off of the wallpaper, sometimes this is a vinyl coating and other times, it is just a dense layer of paper. This should leave only the backing material and glue. Prepare a wallpaper stripping solution consisting of water and a little dishwashing detergent.
Wallpaper stripping solution should be sponged on the backing material and allowed to soak (re-wetting as necessary) for at least 10 minutes. A cheap garden-type sprayer will tremendously speed up the soaking process. Attempt to remove the backing material with a wallpaper scraping tool or alternately any flat bladed tool such as a wide putty knife. If this fails, re-wet the backing and allow to soak longer. The more you soak, the easier the job.
If the above stripping solution is not working well enough, you may also try a solution of 2 parts water to 1 part white vinegar and use the same technique. This stripping solution is only effective against wallpaper installed using wheat or starch based wallpaper adhesives. If the adhesive is unknown, use a generic stripper product.
If you have really stubborn wallpaper, obtain some Safe and Simple online http://www.safeandsimple.com from your local home improvement store, and follow the bottle's directions to remove the remaining backing material.
If you plan on painting the area you just stripped, you must ensure that all the glue behind the backing is removed. To tell if there is still glue remaining, wet the wall and feel it. Any slimy areas mean there is glue left over.
To remove any remaining glue, mix 2 tablespoons of liquid fabric softener into a gallon of water and scrub. You must also carefully rinse the entire wall surface so there are no traces of paste or wallpaper stripper remaining behind, before you paint.
If your vinyl/dense paper facing does not want to peel off the backing, you may try to dry peel it off the wall which may or may not cause wall damage. Paper scoring tools can damage the drywall underneath the wallpaper, but are gentler on plaster walls.
Ensure you read the directions on the package for complete instructions, but a good rule of thumb is to let the tool do the work. Additional lateral pressure will cause undo damage to the wall surface. An alternate method is to use a razor to score a series of Xs into the wallpaper surface. This requires a careful touch as to not damage the underlying wall surface.
In some cases, the scoring and soaking steps will promote or enhance the stripping of the facing material, so after this step, attempt to removing the facing material again. If still no success, you will have to perform repetitive score, soak, and strip steps to remove your wallpaper.
Special Effects with Wallpaper:
http://forum.doityourself.com/showth...914#post654914
  #2 (permalink)
Old 01-03-04, 04:47 PM
Sharp Advice's Avatar
Admin, Forums Host & Manager
Thumbs up DIY'S Wallpaper Help Page & Shopping Center
Welcome To Do-It-Yourself.com and the Wallpaper forum topic. DIY offers the pages below for your shopping pleasure and convenience.
Do-It-Yourself.Com's own wallpaper web pages:
http://doityourself.com/wallpaper/index.htm
DIY'S Wallpaper, Drapery, Window Fashions, Tools And Supplies:
http://doityourself.com/store/paintandsupplies.htm
DIY'S Associated Supplies And Accessories Pages:
DIY'S Patching And Plastering Supplies Shopping Center:
DIY'S Hardware Store:
http://doityourself.com/store/hardware.htm
DIY'S Home Repair, Remodeling Store:
DIY'S Additional Shopping Centers Pages Presented Below:
Here you'll find many of the web sites shopping pages and those of the largest online hardware shopping center on the entire internet.
DIY'S Interactive Web Site:
In Conjunction With Lowes. Cool Projects and Hot Products.
http://www.doityourself.com/ialib.htm
DYI'S Accessories:
http://doityourself.com/accessories/index.htm
DIY'S Main Store Entrance Pages:
http://doityourself.com/store/index.htm
DIY'S Products, Showcases and Links:
http://links.doityourself.com/cgi-bin/search/diy.cgi
DIY'S How to Find Products and Place an Order:
http://doityourself.com/sitemap.htm
DIY'S Home Repair & Remodeling Store And More:
DIY'S Help Center:
http://cs.doityourself.com/needhelp.htm
DIY'S Customer Service Center:
DIY'S Need a Pre-Qualified Local Contractor Referral?
DIY'S Product Manufacturers Web Pages: 905 Pages Offered Here.
http://doityourself.com/store/sortbymanufacturer.htm
DIY'S Shopping Page Central:
DIY'S Electrical Lighting, Parts and Supplies Center:
http://doityourself.com/store/electricalandlighting.htm
DIY'S Hand Tools Center:
http://doityourself.com/store/handtools.htm
DIY'S Power Tools & Accessories:
http://doityourself.com/store/power...accessories.htm
DIY'S Warehouse, Advertisers & Vendors:
DIY'S Books, Plans And Videos:
http://doityourself.com/store/videosbooksplans.htm
DIY'S Helps, How To's & Services Section Pages:
DIY'S Help Center:
DoItYourself.com "In The Media:"
http://doityourself.com/media/index.htm
Shop the DIY superstore. You'll be glad you did.
Quality products, member prices and excellent service.
DIY Will Be Adding Additional Products, Vendors, Advertisers And Web Pages All Year. Visiting These Pages Often, Will Provide An Expanded Lineup As DIY Grows.
  #3 (permalink)
Old 11-20-04, 07:24 AM
Thumbs up FYI: Answers to Wallpapering, Painting & Decorating Questions
Wallpapering, Painting and Interior Design Informational Pages:
Decorating your home is an important part of this time of year. From hanging lights to putting knick knacks on your fireplace mantel, it wouldn't be a holiday season without all of the colorful decorations.
Some may take this time of year to do more serious decorating, or at least start planning on doing some redecorating once the holidays are over and the house needs a clean up job.
Don't know where to start? DoItYourself.com has numerous questions and answers (direct from our Community Forums) on basically every aspect of home decorating from wallpapering, carpeting to refinishing furniture.
Below are sample articles that deal with wallpapering, painting and interior designing. Get ideas on how to choose a theme for child's room, how to add textures in paint, how to paint dark wood paneling and more.
Wallpapering:
http://doityourself.com/decor/answer...questions2.htm
Painting:
http://doityourself.com/decor/answer...questions1.htm
Interior Design:
http://doityourself.com/decor/answer...questions3.htm
Web Site Host & Forums Monitor.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Closed Thread
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
