cancel
Go Back   DoItYourself.com Community Forums > Hardware, Tools, Home & Business Security Center > Tools, Sharpening and Power Machinery
Tools, Sharpening and Power Machinery Hand Held & Power Tools. All Power Machinery and Tool Sharpening. Repairs, Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 11-04-09, 12:49 PM
a little help with a air master compressor tiger 8/50
i have for a fair few years had this unit but only just noted could have been like this all the time as only used once in a while the gauge (there are two)
please copy and paste to get pic of smaller item
http://www.machinemart.co.uk/images/...large/0017.jpg
all works ok but the first dial goes up to 125 psi on charging 115 psi is the where the red starts 175 psi is where the red stops and only cuts out in the red line is this normal
i am only just cheaking as i only use this for spraying and blowing dust,car pressure and just want to be safe
thanks for any help
  #2 (permalink)
Old 11-04-09, 01:53 PM
Topic Moderator
Welcome to the forums!
While I'm not familiar with that particular unit, 120 psi would likely be the maximum output. The 1st gauge tells how much pressure is in the tank, the 2nd works with the regulator and sets how much working pressure is released from the tank.
__________________
retired painter/contractor avid DIYer
  #3 (permalink)
Old 11-04-09, 02:58 PM
what i am looking at is the fact that the gauge is in the red befor powering down the danger zone acording to the gauge
or is this just normal
thanks angel
  #4 (permalink)
Old 11-04-09, 03:25 PM
GregH's Avatar
Super Moderator
Yes, it is not right that the tank pressure operates in the red.
Some compressors, especially inexpensive ones are now coming set to higher pressures than needed.
Most air tools are designed to operate at 100 psi and much more than this just places wear on the compressor.
Make sure though that the gauge appears to be reasonably accurate. (When there is no pressure in the tank does the needle rest on zero?)
You can set this by making adjustments to the pressure switch but it is not always simple.
A good setting would be to cut off at 115 psi and come on at 90 psi.
This would give you decent cycling.
If you want to adjust the control describe the model of pressure switch you have or even better is if you are able to take a clear close-up picture and post it on a free site like Photo Bucket.
__________________
GregH...HVAC/R Tech
  #5 (permalink)
Old 11-06-09, 02:07 PM
where would i fine to pressure switch on this model
any help with this
thanks angel
  #6 (permalink)
Old 11-06-09, 03:44 PM
GregH's Avatar
Super Moderator
The pressure switch is the black box with the wires coming from it but I don't suggest you touch it unless you are absolutely sure what you are doing.
They often have two adjusting screws and you need to turn the right one.
The compressor model does not help with this and you either need to have the exact model of the switch or a clear close up picture of the insides of it.
__________________
GregH...HVAC/R Tech
  #7 (permalink)
Old 11-06-09, 04:41 PM
how to get a close up pic would this be of the inside if the switch box or on the out side
there is a brass bit coming out of the side of the box with a plastic cover
thanks angel
  #8 (permalink)
Old 11-06-09, 05:37 PM
GregH's Avatar
Super Moderator
We need to see what the inside looks like, specifically the adjustment screws if there are any.
Make sure it is unplugged.
__________________
GregH...HVAC/R Tech
  #9 (permalink)
Old 11-07-09, 01:55 AM
so i need to take off the plastic cover on the first regulator
the one with the on and off swich
thanks for the help
angel
  #10 (permalink)
Old 11-07-09, 11:58 AM
heres a copy and paste link to pic of switch and ajusters
http://i510.photobucket.com/albums/s...f/DSCN0449.jpg
thanks for any help
angel
  #11 (permalink)
Old 11-07-09, 01:43 PM
GregH's Avatar
Super Moderator
Nice picture!
There should be some indication what each of the larger two springs adjust.
One should be something like "range" and the other "differential".
Sometimes they say "cut in" and "cut out" but not often.
You want to turn the nut on the spring that says range and you would turn it counter clockwise to loosen pressure on the spring.
Pay attention to the cut in and out before you change anything and write it down.
Turn the range screw one turn ccw to loosen pressure on the spring and see what happens.
__________________
GregH...HVAC/R Tech
  #12 (permalink)
Old 11-08-09, 01:53 AM
heres more of a clear pic of the top view as you can see no markings watso ever
http://i510.photobucket.com/albums/s...f/DSCN0446.jpg
so shall i ajust the left or the right hand side i could twist one turn at a time and count how meny times i have done it but what would happen if i done the right one would i see the differance right away eg the power stopping befor gauge goes in the red or would i have to trun a few times befor ajustment makes any diffrance
thanks angel
  #13 (permalink)
Old 11-08-09, 03:15 AM
hi thanks for all your help have got it sorted now went out for an hour found the first one you see in pic the one that is the closest to you in the pic is the cut out the second is the start apon setting the first 3.5 turns counter clockwise set it at 115 psi just below the red line then moved the 2nd nut clock wise about 3 turns (set it at about 85psi) was needed then you needed to make small ajustments as moving one nut makes a small amount of differance to the other ajustment
all in all 3 turns counter clock on the first and then 3 clockwise on the second with small mucking about at the end
after doing this lost all the air and cleaned glass filter and all the air is now clean it was coming out at first with a little water in the first few blasts of air
again thanks for all the help hope the explanation helps any one else
angel
  #14 (permalink)
Old 11-08-09, 03:22 AM
ps have just cheaked the oil on the moter and i lookes to be a litte high (must have been like this for as long as i have had the air com for)
i only use the compresser for spraying my motor bikes only done 3 or 4 bikes blowing up tyres and cleaning out inside of pcs to get rid of all the dust
the oil level is about 5 mm above max as air com is sat on a fairly level floor
will i need to take out some of the oil or are there any cheaks i need to look at befor making oil ajustments
again thanks for any help
  #15 (permalink)
Old 11-08-09, 02:05 PM
hi any help would be great thanks angel
  #16 (permalink)
Old 11-10-09, 06:59 AM
take a little out
You don't want the crankshaft hitting it, just the little dipper on the bottom of the con rod. Nothing to it but to loosen the drain bolt a little.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
