| Thermostat wiring... pls help I just purchased a Hunter 44860 programmable thermostat to replace my old thermostat. My old thermostat was a mechanical honeywell from the 90s wires attached: R, G, Y, W. There are other wires back in the wall that are capped off. I want to make sure I wire the new system correctly. The Instruction book has instructions for conventional hvac and heat pump. I have a heat pump w/ a gas furnace. thanks in advance for the help! |
