cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Thermostatic Controls
Thermostatic Controls Thermostatic controls for low voltage, line voltage and zoned heating, air conditioning and cooling systems. Installations, Repairs, Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 01-06-09, 02:22 PM
Two Thermostats to control one Central Air System
Hi.
I am looking at replacing our central Air / Gas furnace HVAC system with a two stage, variable speed HVAC system.
Our house is 2 stories and I would like to be able to control the cooling and heating from both floors. Are there Thermorstats that work in conjuction with one another and do they "average" the temps between the 2 floors?
  #2 (permalink)
Old 01-06-09, 08:49 PM
Jay11J's Avatar
Topic Moderator
Yes, there are a couple of t-stat that Honeywell offers to do reading and avg out the temps.
How big of a temp change between floors for you?
You may find that a new two stage system with two stage t-stat will give you far better temps control.
I have a split level home, and all of the room are with in 1˚ from one another on a single t-stat.
__________________
-Jay
If you can do it, We can help.
  #3 (permalink)
Old 01-06-09, 10:07 PM
great idea then when the upstairs get too hot from the heat on below you can turn on the air conditioning at the same time..
  #4 (permalink)
Old 01-07-09, 05:15 AM
Jay11J's Avatar
Topic Moderator
Quote:
No, the t-stat will not turn on the A/C at the same time. If it get that hot up there in the winter, you have a duct design issues.
__________________
-Jay
  #5 (permalink)
Old 01-07-09, 08:40 AM
We don't have a huge difference in temps between the upstairs and downstairs, but it's more than 1 degree, probably 2 or 3. In the summer, the difference is more obvious.
My reason for having two thermostats is more for convinience. It's nice not having to go up/down a flight of stairs to change the temp or to just turn on the fan.
  #6 (permalink)
Old 01-07-09, 01:53 PM
Jay11J's Avatar
Topic Moderator
Honeywell just came out with nice wireless remote control system if you need to have something upstairs.
I program mine, and I don't even touch it unless I am home from work that day.
With it being warmer upstairs in the summer, you have good attic vent? Returns up stairs?
__________________
-Jay
  #7 (permalink)
Old 01-08-09, 09:44 AM
I have 8 inches of insulation on the attic and an electric attic vent for summer, but when summer hits, the upstairs gets very hot very quickly and there is a bigger temp difference between the floors during those hot days.
The ideal setup is to have two independant heating/cooling systems, each one doing one level, but that is costly and in some cases impossible because of the duct setup
  #8 (permalink)
Old 01-08-09, 10:39 AM
Jay11J's Avatar
Topic Moderator
Quote:
That's not enough. With that, you got about R-25 up there, and R-40 to R-44 is suggested in northern states. (around 12 to 14") as high as R-60 (19")
__________________
-Jay
  #9 (permalink)
Old 01-08-09, 03:49 PM
Yes, I probably don't have enough. I live in southern California, not north. Still, the summers can get very hot very quickly.
  #10 (permalink)
Old 01-08-09, 04:21 PM
Jay11J's Avatar
Topic Moderator
I thought I read some where you were in New York.. My bad..
But yeah if you do add more, it will help cut down on the heat load in the summer. Even tho you do have a fan up there, it still what ever the temps is outside.
__________________
-Jay
  #11 (permalink)
Old 01-08-09, 09:26 PM
Yes, Honeywell has a complete new line of Wireless controls called Redlink. You can do about anything you ever wanted to now, its amazing.
RedLINK™ Wireless
  #12 (permalink)
Old 01-09-09, 06:05 AM
Jay11J's Avatar
Topic Moderator
Only down fall I've found with the new Red-Link, they don't have hook up for fresh air control.
__________________
-Jay
HTML code is On
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Content Relevant URLs by vBSEO 3.2.0
