cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Thermostatic Controls
Thermostatic Controls Thermostatic controls for low voltage, line voltage and zoned heating, air conditioning and cooling systems. Installations, Repairs, Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 11-08-08, 03:44 PM
Question T-Stat help needed
Hiya folks ol Torch here with another question,
These folks had their Coleman QED II condensing unit hooked into an Intertherm MG H 055A B Air Handler/furnace, and it was rigged wired way bad haha (of course I'm in the boonies)
My question is that the red wire from the t-stat goes to the #1 terminal on the fan delay switch, now where in the heck does the #2 terminal go to? (going to that second exterior terminal now) It was an original heat only system and has two contacts on the outside of the controller box, but inside they have rigged a red wire that is heading to the contactor as is the other lead from it. Do I break the second lead wire that is contacted to the contactor and attached it to the delay switch? I'm way confused here lol. They are NOT going to be running heat from this system, air only. They have a Trane Heat/Cool t-stat.
  #2 (permalink)
Old 11-08-08, 06:07 PM
I got it lol hahahahaha......
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
