cancel
Go Back   DoItYourself.com Community Forums > Flooring and Floor Coverings Center > Solid Hardwood, Engineered and Laminate Flooring
Solid Hardwood, Engineered and Laminate Flooring Selection, installation, finishing, refinishing, maintenance and repair.
Thread Tools Display Modes
  #1 (permalink)
Old 06-18-01, 06:40 AM
Question
Just purchased laminated flooring. What is the best saw to use to cut the flooring I know I need at least a 60 to 100
tooth blade. But I have access to the following saws but not sure which to use.
12 inch sliding mitre
10 in table saw
Band Saw
Radial Arm Saw
  #2 (permalink)
Old 06-18-01, 07:15 AM
AzFred
The table saw will work best on longer rips that I doubt you can avoid and will also handle cross cuts or length reduction. The chop saw is fast and easy for most cuts otherwise. A sharp blade is most important and laminate flooring is tough on those. Use a carbide tipped blade and have it sharpened often if frequent cuts are needed. Most if not all cut edges will be hidden by molding and a 60 tooth blade should work fine. Rub some silicone caulk into the cut edges when installing the planks that have been cut. hope this helps and Good Luck with your project.
  #3 (permalink)
Old 03-13-09, 05:55 PM
Laminate floor "pergo" cutting tool
Google "laminate floor cutting tool". You will find a manual cutter similar to the old trusty paper slice. Feedback I got from users is "it's the best thing since sliced bread"
Try this link Toolmonger Blog Archive Giant Laminate-Floor-Cutting Scissors
  #4 (permalink)
Old 03-13-09, 06:11 PM
HotinOKC's Avatar
You do know this thread hasn't had a reply in 8 years, right?
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
