| water entering between the door sill and the bottom of the door Hi. I've got an external door that takes direct rain. Water collects on top of the sill in the 1-2mm gap between the sill and the bottom of the door, and then drips into the interior of the room. I've sanded the sill (directly beneath the bottom of the door) so that it slopes slightly - i'd hoped that this would allow the water that splashes up into the gap to run off; but this hasn't worked, and i think it has actually made the problem worse (i.e., because I've now created a slightly larger gap). Any solutions would be greatly appreciated. Thanks. |
