Quote:
Originally Posted by bbry81 My master bathroom plumbing gets clogged about once every 6 months. I believe my house has shifted which has cracked the pipe so it gets clogged easily. I have tried to find the clean out vaulve outside my house with no luck. If it is under the slab would i fix the slab first the do the piping. just trying to figure out my process. also any hints on finding my clean out would be helpful. plumbers not so helpful when they come out. |
That doesn't compute, with a broken line you would have a problem with ALL your drains.
Unless you are willing to pay plumbers to look for your c.o. they are not going to find it for free.
You c.o. should be close to the house where the sewer comes out, but it could have been installed too low and it now is covered up. It's also possible that one wasn't put in.
If your c.o. is under the slab wouldn't make any sense at all.
From the information I'm getting from your post leaves me to say that you have to start in your master bath area and look for the problem there.
BTY Do you have a habit of putting things down your toilet that don't belong there, like paper towels, hand wipes, tampons etc., if you do that could explain why your toilet stops up periodically?
