cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Plumbing and Piping
Plumbing and Piping Cleaning, fixing, installing, replacing drains, traps, mains, drainage, sewage, water and gas lines. Valves: ball, gate, directional, flow, pressure control, earthquake and regulation, etc.
Thread Tools Display Modes
  #1 (permalink)
Old 02-12-09, 10:57 AM
Hot Water Boiler Radiant Heat
What kind of connections would I need to put in hot water radiant heat from a 20yo+ cast iron hot water boiler? Is it true that I will need a mixing valve to regulate the temperature? At what point does the plastic tubing connect to the hot water line?
Tags
radiant heat
Smilies are Off
HTML code is On
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
