cancel
Go Back   DoItYourself.com Community Forums > Interior Home Improvement Center > Paneling and Trim
Paneling and Trim Processes, Methods, Procedures to Know, Tools and Materials, etc.
Thread Tools Display Modes
  #1 (permalink)
Old 11-21-08, 08:32 AM
To apply polyurethane before or after trim intall?
I am planning to stain the trim in a basement finishing project that I am getting close to completing. I am going to use a stain, followed by a coat or two of polyU.
My plan was to paint the walls, then measure and cut the trim. After all the trim was cut, I was going to stain/poly it, then install it. Last, I was going to fill any nail holes and touch-up with more polyU. Does that make sense?
Or should I stain (but not poly), then install the trim? Then, after filling the nail holes, I can apply the polyU.
Thanks,
Guy
  #2 (permalink)
Old 11-21-08, 08:58 AM
Gunguy45's Avatar
Topic Moderator
Go with your original plan..
__________________
Vic
I'm no expert, but don't tell my wife that.
  #3 (permalink)
Old 11-21-08, 11:29 AM
XSleeper's Avatar
Sounds good, but I can't imagine why you would cut the trim first! Stain and finish it all, then cut and install, fill nail holes, touch up poly.
  #4 (permalink)
Old 11-21-08, 11:34 AM
Gunguy45's Avatar
Topic Moderator
Ouch....well it was early when I read it....
Yes, as X said...stain and poly it all first. You can touch up the cut ends with a StainStick (lighter shade than the main stain, it will look darker on the cut end) before install.
__________________
Vic
  #5 (permalink)
Old 11-21-08, 04:44 PM
Topic Moderator
I would add, if you stain before installing, you need to apply atleast 1 seal coat also - this will prevet the stain from getting messed up during handling. My normal SOP on stained homes is to stain, spray sanding sealer, let the carpenter install, touch up stain as needed, putty, sand,dust, apply varnish,sand and recoat as needed.
As a diy project, I believe you would benifit from sanding and apply the 2nd coat of poly before installation. I agree with XSleeper that it makes mnore sense [quicker/easier] to stain and finish before cutting. Unless you sand any exposed cuts they will stain darker, I often cheat by thinning the stain some for those areas
__________________
retired painter/contractor avid DIYer
  #6 (permalink)
Old 11-21-08, 05:15 PM
Quote:
Originally Posted by marksr View Post
My normal SOP on stained homes is to stain, spray sanding sealer.
What product do you use for this?
... apply varnish...
Do you use polyurethane or a different varnish for trim?
  #7 (permalink)
Old 11-21-08, 05:31 PM
Topic Moderator
I generally use sanding sealer for the 1st coat and varnish for the top coats. I buy mine at SWP but any paint store will have the equivalent. The reason I use sanding sealer is it dries faster and sands easier than polyurathane. Most polys aren't compatible with sanding sealer so I use varnish. Varnish doesn't dry as hard as poly but it allows me to do a nice acceptable job in the shortest/easist time frame.
That's not to say one coating is better than the other - they both have good points. It's up to you to choose which finish is best for you
__________________
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
