cancel
Go Back   DoItYourself.com Community Forums > Cars, Trucks, RV's, Boats and Outdoor Power Equipment > Outdoor Power Equipment and Small Engines
Outdoor Power Equipment and Small Engines Lawn, Yard, Garden and Shop Gasoline Engine Powered Machinery.
Closed Thread
Thread Tools Display Modes
  #1 (permalink)
Old 09-09-01, 05:20 PM
Sharp Advice's Avatar
Admin, Forums Host & Manager
Arrow FYI: Engine Specifications, Decipher Codes & OEM Home Pages
Model and Serial Number Deciphering Codes.
Engine Maintenance and Service Specifications.
POST NO REPLIES.
Original Posting Date: 09/09/01
"Tecumseh" engine code decipher list.
V = Vertical Shaft
LAV = Lightweight Aluminum Vertical {engine}
VM = Vertical Medium Frame {engine}
TVM = Tecumseh Vertical {medium frame}
VH = Vertical Heavy Duty {cast iron}
TVS = Tecumseh Vertical Shaft
TNT = Toro N' Tecumseh
ECV = Exclusive Craftsman Vertical
OVM = Overhead Valve vertical Medium Frame {engine}
H = Horizontal Shaft
HS = Horizontal Small Frame {engine}
HM = Horizontal Medium Frame {engine}
HHM = Horizontal Heavy Duty {cast iron} Medium Frame {engine}
HH = Horizontal Heavy Duty {cast iron}
ECH = Exclusive Craftsman Horizontal
An Example is: TVS90-43056A serial #8310C
90 = 9 Cubic Inch Displacement
43056A = Specific number for parts identification
8310C = Serial number
8 = Year of manufacturing {1978}
310 = Calendar day of the year {310th day in year of 1978}
C = Assembly line and shift when the engine was built.
SBH = Short Block Horizontal
SBV = Short Block Vertical
OH = Overhead Valve Heavy Duty {cast iron}
Examples: OH160...OH120
Overhead Valve 160 equals 16 horsepower
Overhead Valve 120 equals 12 horsepower
Recommended oil viscosities for Aluminum Engines:
Above 32 degrees: 30 weight or 10W30 or 10W40
Below 32 degrees: 5W30
Below 0 degrees: 5W30 or 10W
Recommended oil viscosities for Cast Iron Engines:
Below 32 degrees: 10W
Spark Plug Gap: .030 inch
Older model engines using points and condensers:
Ignition Point Gap: .020 inch
Valve Clearance: .010 both intake and exhaust
Web Site: http://www.Tecumseh.com
"Briggs and Stratton" engine code decipher list.
The first one or two digits indicate the
"Cubic Inch Displacement"
The first digit after the displacement indicates:
"Basic Design Series"
The second digit after the displacement indicates:
"Position Of Crankshaft and Type of Carburetor."
The third digit indicates:
"Type of Bearings" and whether the engine has a "Reduction Gear" or an "Auxiliary Drive."
The last digit indicates: the "Type of Starter."
Cubic Inch Displacements are listed between 6 to 42.
Basic design series {first digit after displacement} are listed between 0 to 9.
Second digit after the displacement is listed 0 to 9:
Crankshaft, Carburetor and Governor types:
0 = Horizontal Diaphragm
1 = Horizontal Vacu-Jet
2 = Horizontal Pulsa-Jet
3 = Horizontal Flo- Jet with Pneumatic Governor
4 = Horizontal Flo-Jet with Mechanical Governor
5 = Vertical
6 = Left Blank...{No Listing Indicated in service manual}
7 = Vertical Flo-Jet
8 = Left Blank...{No Listing Indicated in service manual}
9 = Vertical Pulsa-Jet
Third digit after displacement:
Bearings, Reduction Gears and Auxiliary Drives types:
0 = Plain Bearing
1 = Flange Mounting Plain Bearing
2 = Replacement Bearing
3 = Flange Mounting Ball Bearing
4 = Left Blank...{No Listing in this service manual}
5 = Gear Reduction of 6 to 1
6 = Gear Reduction of 6 to 1 with Reverse Rotation
7 = Left Blank...{No Listing in this service manual}
8 = Auxiliary Drive Perpendicular to Crankshaft
9 = Auxiliary Drive Parallel to Crankshaft
Fourth Digit After Displacement:
Type Of Starter Used:
0 = Without Starter
1 = Rope Starter
2 = Rewind Starter
3 = Electric Starter 120 Volt Gear Drive
4 = Electric Starter with generator 12 Volt with Belt Drive
5 = Electric Starter Only 12 Volt Gear Drive
6 = Alternator Only*
7 = Electric Starter 6 or 12 Volt W/Gear Drive & Alternator
8 = Vertical Pull Starter
* Digit 6 was used for the currently obsolete
"Wind Up Starters."
Starter Position:
V = Vertical Pull Starter
Oil Fill and Drain:
CS = Carb Side
OC = Opposite Carburetor
D = Dual Side
Governor Types:
AV = Air Vane
M = Mechanical
Controls:
MF = Manual Friction
R = Remote
AG = adjustable for a constant speed of operation {RPM}
I/C Series means Industrial/Commercial applications.
Oil Capacities for Aluminum Engines:
6, 8, 9, 11 cubic inch Vertical Crankshaft:1 and a 1/4 pints
6, 8, 9 cubic inch Horizontal Crankshaft: 1 and a 1/4 pints
10, 13 cubic inch Vertical Crankshaft: 1 and 3/4 pints
10, 13, cubic inch Horizontal Crankshaft: 1 and a 1/4 pints
14, 17, 19 cubic inch Vertical Crankshaft: 2 and a 1/4 pints
14, 17, 19 cubic inch Horizontal Crankshaft: 2 and 3/4 pints
22, 25 cubic inch Vertical & Horizontal Crankshafts: 3 pints
Oil Capacities for Cast iron Engines:
9, 14, 19, 20 cubic inch Horizontal Crankshaft engines:
3 pints
23, 24, 30, 32 cubic inch Horizontal Crankshaft engines:
4 pints
Oil SAE Viscosity Grades: {OEM Suggested}
-20 Degrees to 20 Degrees *5W-20 or 5W-30
0 Degrees to 60 Degrees 10W-30 or 10W-40
40 Degrees to 100 Degrees 30 weight or 10W-30 or 10W-40
* Synthetic oil may be used: 5W-20, 5W-30 or 5W-40
OEM suggested oil change intervals for ALL engines is
25 hours.
OEM suggested air filter replacement intervals is
25 hours.
ALL spark plug gaps are .030
Crankshaft End Play for ALL models is: .002-.008 thousands.
Condenser capacity for ALL models is: .18 to .24 MFD
ALL models have an ignition point gap of .020
Valve Clearances:
All Aluminum Cylinder Engines:
6B, 60000, 8B 80000 to 250000
Intake Minimum .005
Intake Maximum .007
Exhaust Minimum .009
Exhaust Maximum .011
All Cast Iron Cylinder Engines:
5, 6, 8, N, 9, 14, 19, 190000, 20000
Intake Minimum .007
Intake Maximum .009
Exhaust Minimum .014
Exhaust Maximum .016
23, 230000, 240000, 300000, 320000
Intake Minimum .007
Intake Maximum .009
Exhaust Minimum .017
Exhaust Maximum .019
Briggs and Stratton Home Page:
http://www.briggsandstratton.com/display/router.asp?DocID=64103
Briggs and Stratton Manuals:
http://shop.briggsandstratton.com/BShopProductListingPage.asp?MecID=100&CatalogID=56B2B9AF-283C-11D4-8886-00B0D0203414&SessionID=503C7FFE-765D-4AC8-A61E-F99FE61A74B5&SMSID=Smart+Search&ViewName=htsDIY&EngineModelNumber=130202&EngineType=0436
LAWN BOY MOWER HOME PAGE
http://www.lawnboy.com/index.html
LAWN BOY MOWER SEARCH BY MODEL NUMBER
https://lookup2.toro.com/partdex/index.cfm?xCaller=lawnboy
TS = Toms Suggestion...
P&S = Print and Save...
Regards & Good Luck. Sharp Advice.
Master Small Engine Tech. Web Site Host, Forums Monitor and Multiple Topics Moderator. "Accurate Power Equipment Company." Small Engine Diagnostics Services & Repair.
Fast...Fair...Friendly & Highly Proficient Services....
PS:
Salvaged from the Archives.
PSS:
If you have the engine models and codes for other engines not listed here, advise me via a PM. Kindly include the Mfg's web site address. I will post them here also.
  #2 (permalink)
Old 12-27-01, 05:22 PM
Arrow FYI: Basic Carburetor Information
Original Posting Date: 12-27-01
Topic: Basic Carburetor Rebuilding Information.
Intent: Basic Information for the first time Do-It-Yourself Person.
Contents: Carburetors used on both 2 and 4 Cycle Gasoline Small Engines. Helpful Suggestions, Tips, VIP Info and Cautions.
Some engine starting or operating conditions and problems may appear to be carburetor related. Always check for fuel flow out of the fuel tank, prior to any suspected fuel related engine problems and prior to removing any carburetor.
Basically, there are 2 types of carburetors used on small engined power equipment. The bowl type and the diaphragm type. Diaphragm carburetors are easy to identify because they do not have fuel bowls.
Diaphragm carburetors are mostly used on 2 cycle engines. Some 4 cycle engines may have a diaphragm carburetor while other 4 cycle engines may have bowl type carburetor.
Prior to removing any carburetor, be sure to make note of exactly how the throttle linkage is connected to the carb and the governor linkage is installed on either end. It's important to reinstall all parts exactly as they where originally installed.
TIP:
Use care handling any springs attached to the carburetors linkage. Be very careful not to overly expand any throttle or governor springs and equally as important not to bend any linkage rods.
Most carburetors have either 1 or 2 fuel adjustment screws. Should there be 2 fuel adjustment screws on either type of carb, one should be marked "H" for the high speed adjustment screw and another marked "L" for the low speed adjustment screw.
IMPORTANT INFO:
Prior to any carburetor disassembly, be sure to make note of exactly how many turns OUT WARDS each fuel adjustment screw is currently set at.
To determine how many turns each fuel adjustment screw is turned out wards, count the number of turns it takes to screw it IN WARDS, until the adjustment screw is lightly seated.
The number of turns in wards it takes to lightly seat the screw, will then be the number of turns out wards it takes to set the screw back to it's originally opened position, after the carburetor rebuilding process is completed.
DURING DISASSEMBLY:
Carefully remove each part of the carburetor and take special note of exactly how each part came off or in the case of part assemblies, exactly how the assembly came apart.
Take special note in which order each part or assembly came off and or came apart. Note which side or which direction each part currently is facing or installed, prior to removal and or disassembly.
IMPORTANT TIPS:
It is highly recommend to only disassemble carburetors on a well lighted, clean and completely cleared off work bench. Carburetor parts are usually tiny, often freely fall out of removed parts or assemblies and can become easily lost.
Using scribe marks on metal parts or assemblies of parts will help to replace the parts in the location each part was installed prior to disassembly.
DIAPHRAGM CARBURETOR NOTE:
On diaphragm carburetors, look for a small hole in the carburetors engine facing side. This hole is bored into the body of the carb around the mounting surface.
On the engine mounting surface is another hole which goes down into the engines crankcase.This hole provides both vacuum and pressure, which must be allowed to enter into the carburetor.
Both holes provide a path for engine crack case vacuum and pressure to act upon the diaphragm, causing it to fluctuate. The diaphragms fluctuations allows fuel to flow into the carburetor. Be sure both holes are cleared.
TIPS:
During the carb cleaning process, use canned aerosol automotive carb spray cleaner. Use it to clean the carb body, fuel ports, jets and airway passages.
The plastic extension tube, that comes with the canned cleaner, is an excellent tool to flush out sludge and debris from the jets, ports, fuel channels, airway passages, under Welsh plugs without removing the plug caps.
CAUTIONARY NOTE:
Use EXTREME CAUTION with canned aerosol automotive parts cleaner products. Aerosol cleaners are EXTREMELY FLAMMABLE!
Read the manufacturers product warning label.
SPECIAL NOTES REGARDING 2 CYCLE ENGINES:
Check for a fuel filter inside the bottom of the fuel tank or installed in-line with the fuel hose. Some two cycle engines may have a weighted fuel filter attached to the fuel hose end inside the fuel tank.
The filter and weight combo should be able to freely move around inside the tank. The purpose of the weighted filter is to allow fuel to be drawn up when the engine is operating at angles.
MUFFLER & FUEL TIPS:
Mufflers on two cycle engines are susceptible to becoming restricted or clogged up with carbon deposits. Should this happen, engine performance will be diminished. If this happens, the muffler will need to be removed, cleaned out and or replaced.
Care should be taken removing any muffler. Breaking off the head of a bolt or damaging the heads of a screw are possible. Be sure to reinstall the muffler and or spark arrester as currently installed.
The best preventative measure to help reduce carbon build up in the combustion chamber, exhaust system and muffler, is to use an ash less two cycle oil or the oil type specifically recommended by the manufacturer. Bare in mind that an overly rich oil to fuel mixture is not beneficial. Too much oil will do more harm then good.
Do not premix any more fuel and 2 cycle oil mixture then can be used in a month. Premix the correct amount of oil to fuel ratio into the fuel in a separate fuel container and store the container in a safe location.
Suggestions:
Read the equipments owners manual. Check the manufacturers product online web site and purchase a repair manual specific to the engine and equipment, if possible. Helpful repair aids provide useful information, problem solving methods, disassembly, reassembly repair procedures, instructions, pictorials and schematics.
An excellent source for original replacement parts, generic service and repair manuals, is your local retail lawn mower and or small engine repair shops. Small engine powered equipment dealers and repair shops are listed in the phone book.
Most retail dealers can help determine what a possible engines problem may be, prior to attempting a carb overhaul. Be sure to take the engines brand name, model and serial numbers with you, if you stop in at the store.
HINTS:
When dealing with shop owners and or their mechanics, it's recommend to "ASK QUESTIONS." Not all repair shops operate the same nor include the same services for the terms and or phrases commonly used. Know the differences.
Question Examples:
Does the engine need a "Minor Tune-Up or a Major Tune-up?" The two are not the same. Ask what each service includes.
Does the engine only need a "Carburetor Adjustment" or a complete "Carburetor Overhaul?" Ask what each service includes. Not all shops operate in the same manner.
TUNE-UP NOTE:
A Minor Tune-up often includes only carburetor adjustments, when needed, with ignition services. A Major Tune-up may or may not include a carburetors complete rebuilding.
UPDATED VERSION.
POSTED 04-16-04
Some engine hard starting, running or operating conditions and problems may appear to be carburetor related. Such may not always be the case. Many possible conditions can cause some problems to appear to be carburetor related conditions but not really be so.
Always check for fuel flow out of the fuel tank, when a carb problem is suspected prior to any suspected fuel related engine problems and always prior to removing any carburetor.
Basically, there are 2 types of carburetors used on small engined power equipment. Diaphragm carbs and bowl carburetors. Diaphragm carburetors are usually easy to spot because they do not have fuel bowls.
Diaphragm carburetors are mostly used on 2 cycle engines. Also
used on power equipment which may need to be turned at angles or not used while in a non level position. 2 such examples would be chainsaws and string trimmers.
Some 4 cycle engines may have a diaphragm carburetor while other 4 cycle engines may have bowl type carburetor. There is no assurance which type of carb is used on mowers and edges, etc.
Once all other possibilities are assured not to exist on the power equipment, only than should the carb be suspected and or removed for service and or repairs.
Prior to removing any carburetor, be sure to make note of exactly how the throttle linkage is connected to the carb and the governor linkage, if equipped, is installed on either end of the linkage. It's important to reinstall all parts exactly as they where originally installed.
TIP:
IMPORTANT INFO:
The number of turns in wards it takes to lightly seat the screw, will then be the number of turns out wards it takes to set the screw back to it's originally opened position, after the carburetor rebuilding process is completed. Write the number of turns down on paper.
DURING DISASSEMBLY:
IMPORTANT TIPS:
On diaphragm carburetors, look for a small hole in the body of the carburetors engine facing side. This hole is bored into the body of the carb around the mounting surface.
TIPS:
This process and procedure above usually works but not always. The intent is to avoid removal of some parts and or carb pieces which are pressed in and or may be more difficult to replace.
CAUTIONARY NOTE:
Mufflers on two cycle engines are susceptible to becoming restricted or clogged up with carbon deposits. Should this happen, engine performance will be diminished. Difficulties with engine running and hard starting are symptoms.
If muffler restriction is suspected, the muffler will need to be removed, cleaned out and or replaced. Care should be taken removing any muffler. Breaking off the head of a bolt, damaging the heads of a screw or the threads, etc are possible. Be sure to reinstall the muffler and or spark arrester as currently installed.
The best preventative measure to help reduce carbon build up in the combustion chamber, exhaust system and muffler, is to use an ash less two cycle oil or the oil type specifically recommended by the manufacturer in the ratios recommended. Bare in mind that an overly rich oil to fuel mixture is not beneficial. Too much oil can do more harm then good.
Do not premix any more fuel 2 cycle oil mixture then can be used in a month. Premix the correct amount of oil to fuel ratio into the fuel in an approved, separate fuel container and store the container in a safe location.
Suggestions:
Most retail dealers can help determine what a possible engines problem(s) may be, prior to attempting a carb overhaul. Be sure to take the engines brand name, model and serial numbers with you, if you stop in at the store.
HINTS:
Question Examples:
Does the engine need a "Minor Tune-Up or a Major Tune-up?" The two services are are not exactly the same. Ask what each service includes.
TUNE-UP NOTE:
Master Small Engine Tech. Web Site Host, Forums Monitor, Manager and Multiple Topics Moderator. "Accurate Power Equipment Company." Small Engine Diagnostics Services & Repair.
  #3 (permalink)
Old 04-16-04, 03:18 PM
Arrow FYI: Engine Codes and Model Numbers Decipher Inforomation
V = Vertical Shaft
5 = Vertical
0 = Plain Bearing
0 = Without Starter
1 = Rope Starter
2 = Rewind Starter
"Wind Up Starters."
Starter Position:
Oil Fill and Drain:
CS = Carb Side
D = Dual Side
Governor Types:
AV = Air Vane
M = Mechanical
Controls:
R = Remote
3 pints
4 pints
25 hours.
25 hours.
Valve Clearances:
Intake Minimum .005
Intake Maximum .007
Intake Minimum .007
Intake Maximum .009
Intake Minimum .007
Intake Maximum .009
Web site: http://www.briggs&stratton.com
Master Small Engine Tech. Web Site Host, Forums Manager, Monitor and Multiple Topics Moderator. "Accurate Power Equipment Company." Small Engine Diagnostics Services & Repair.
  #4 (permalink)
Old 02-21-05, 07:39 AM
Thumbs up Electric Mowers Web Sites & Information Pages
Do-It-Yourself Electric Mowers:
http://doityourself.com/store/electricmowers.htm
Clean Air Gardening:
http://www.cleanairgardening.com/index.html
Electric Lawn Mowers:
http://www.cleanairgardening.com/electricmowers.html
http://funairline.com/electric-lawn-mower-neuton.html
Country Home Products:
http://www.countryhomeproducts.com/navHome.aspx?SiteEntryMode=0
People Powered Machines:
http://www.peoplepoweredmachines.com/index.html
Gardens Math Web Site: (Lawn Size)
http://www.hgtv.com/hgtv/gl_gardening_basics/article/0,1785,HGTV_3589_1396212,00.html
Econogics Outdoor Power Equipment Page:
http://www.econogics.com/ev/evtools.htm
How To Buy An Electric Lawn Mower Page:
http://www.ehow.com/how_17886_buy-electric-powered.html
Consumer Search Lawn Mowers Reviews:
http://www.consumersearch.com/www/lawn_and_garden/lawn_mowers/
Popular Mechanics Walk Behind Mowers:
http://www.popularmechanics.com/home_improvement/databases/ope/1325631.html
Outdoor Equipment Buyers Guide:
Manufactures By Brand Names: (1-151 Models)
http://www.popularmechanics.com/home_improvement/databases/ope?tool_action=list_tools&c=y&tool_type_id=41
Closed Thread
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
