cancel
Go Back   DoItYourself.com Community Forums > Cars, Trucks, RV's, Boats and Outdoor Power Equipment > Outdoor Power Equipment and Small Engines
Outdoor Power Equipment and Small Engines Lawn, Yard, Garden and Shop Gasoline Engine Powered Machinery.
Thread Tools Display Modes
  #1 (permalink)
Old 11-06-09, 08:51 PM
Murray blade sharpening
I just sharpened the blades on my 42 inch Murray lawn tractor model 42591x31A. Just want to verify if I'm correct in how much of the blade I sharpen. The blades are shaped like a lazy "Z" with the bottom of the "Z" being the outermost edge. This is the area I sharpen, which is probably 3 inches or so at most. My reasoning is that this is the lowest part and the part that makes the finishing cut on the lawn. Is there any reason to sharpen any other areas? Also, I run throttle on engine at approximately 3/4, is this adequate on these models to get best cut?
  #2 (permalink)
Old 11-06-09, 11:04 PM
Mower blades
If you don't have a mulching blade than you would just sharpen the last 2 or 3 inches of the blade here is a mulching blade:
You should mow at full throttle for the highest blade tip speed to get the best cut.
AJ
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
