cancel
Go Back   DoItYourself.com Community Forums > Cars, Trucks, RV's, Boats and Outdoor Power Equipment > Outdoor Power Equipment and Small Engines
Outdoor Power Equipment and Small Engines Lawn, Yard, Garden and Shop Gasoline Engine Powered Machinery.
Thread Tools Display Modes
  #1 (permalink)
Old 10-30-09, 01:40 PM
serial numbers
i have what appears to be a seiral number and i was wondering if anybody could use ut to idenify a tecumseh engine the number is under the flywheel(covered up by it) stamped on the engine block with a circle around it the number is
1A10287
  #2 (permalink)
Old 11-01-09, 05:33 PM
anybody anything yet i could really use it if you want any more info i will give you all i have it is very old 50s or 60s off of a jacobsen imperial 26 2 stage heavy duty snowblower it is either 8 or 7 hp float type carborater centerfugal governer horizontal shaft 4 cycle lauson carb anything else i will try my best just let me know
  #3 (permalink)
Old 11-01-09, 10:06 PM
That is just a casting stamp it is of no use.
What are the numbers on the carb?
AJ
  #4 (permalink)
Old 11-02-09, 01:44 PM
ok i am goint to do my best to give you locations i am going to give you every number on it on the top on the exhust side the numbers 110 and then what apears to be a space then 9E13 so it appears as 110 9E13 that is right under the trottle screw now on the side of the carb is the number 40 stamped in a circle now on the other side of the carb is the number 16 on the bottom of the float bowl is lauson power products grafton wis. made in the u.s.a patenit pending
  #5 (permalink)
Old 11-02-09, 03:59 PM
Tecumseh
The carb service part number is 630992B it was built on May 13, 19?9 it fits on a very long list of H50 & H60 engines 5HP & 6HP
They did make a 626 do you have the UT number from the plate on the back of the machine?
AJ
  #6 (permalink)
Old 11-03-09, 01:20 PM
yea i dont have that this isnt the 626 model i have definatly identifyed that it is the 26 how do i tell witch horse power it is becuase as it stands for me it seems to be much larger that a 5 or a 6 either a 7 or an 8hp but i will definatly look those up and the question mark in the date does that mean you dont know or that you just made a typo
  #7 (permalink)
Old 11-03-09, 07:55 PM
Tecumseh
The question mark in the date means that it was built in 69 or 79 or 89 as far as I know there is no way to tell which. Please post some pictures of the engine.
AJ
  #8 (permalink)
Old 11-05-09, 05:47 PM
i will if someone will explain how to
  #9 (permalink)
Old 11-05-09, 05:51 PM
  #10 (permalink)
Old 11-06-09, 10:40 PM
Add a picture
Quote:
To post a picture you must first upload it to a server that has access to the web. You can get a free account at Image hosting, free photo sharing & video sharing at Photobucket and than you simply click on the picture icon in the message editor and insert the link to the photo. Here is what a link to a picture looks like:
http://i78.photobucket.com/albums/j1...llen/tcarb.jpg
Here is the picture:
  #11 (permalink)
Old 11-08-09, 05:09 PM
[/IMG]
  #12 (permalink)
Old 11-08-09, 05:12 PM
i actednit made a mistake so yea
  #13 (permalink)
Old 11-08-09, 05:17 PM
  #14 (permalink)
Old 11-08-09, 05:20 PM
  #15 (permalink)
Old 11-08-09, 10:09 PM
indypower1's Avatar
If this is the engine that was originally on that snowblower, it is a 1969 or 1979. The lack of engagement handles on the handle bars tell me it is pre-1989. The size of the gas tank tells me it is a 7 or 8 hp engine.
  #16 (permalink)
Old 11-09-09, 02:00 PM
any way to norrow down to a model number
  #17 (permalink)
Old 11-09-09, 02:05 PM
my great grand father (rest in peace) gave this to me and i remeber him saying it lasted up until the 80s so its not 1989 its origanal color was white i have had the engine completely disasembled so if you need anything that could help you identify it just let me know i could take it apart with my eyes closed
  #18 (permalink)
Old 11-10-09, 08:11 AM
indypower1's Avatar
After reading this and looking again at the photos, the engine is a 1969. What gave it away is the so called "primer" that is actually just an extra choke, the button on the carb that you push. It is either a 7 or 8 hp. It has points.
  #19 (permalink)
Old 11-10-09, 03:15 PM
so do you have any idea what i could do with the info you just gave me to narrow down and possibley get a manual
  #20 (permalink)
Old 11-17-09, 01:23 PM
so mabey if anybody knew anybody with a jacobsen imperial 26 and i could get the model number from them that might work
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
