cancel
Go Back   DoItYourself.com Community Forums > Cars, Trucks, RV's, Boats and Outdoor Power Equipment > Outdoor Power Equipment and Small Engines
Outdoor Power Equipment and Small Engines Lawn, Yard, Garden and Shop Gasoline Engine Powered Machinery.
Thread Tools Display Modes
  #1 (permalink)
Old 01-05-09, 09:09 AM
poulan pro 295 chainsaw won't start
I was trying to cut some wood the other day and I got the saw to start, it ran for about 30 seconds and then died. Sounded like it ran out of gas, but was full of gas and oil. Pulled on it for an hour, with both the choke on and off, no luck. So I took apart the carb and cleaned it a bit, not thoroughly though and put it back together. Still won't start. Has compression, pull spins a lot easier with plug out. Plug seems to have spark, and seems to have fuel flowing (when I pull the plug and pull the cord mist comes out of the cylinder.
Would the on/off switch go bad and cause this problem? If I just shorted out the two wires going to the switch, is that the same as if it were in the on position?
What other problems would cause this and any ideas on how to fix it?
Any help would be greatly appreciated. I need to get some wood cut before it gets too cold and my wife freezes.
  #2 (permalink)
Old 01-05-09, 09:18 AM
Not if you are getting spark. Are you sure you are getting spark? Replace the plug as a starting point, plug may be bad even though it looks ok.
  #3 (permalink)
Old 01-05-09, 08:44 PM
I took the plug out and grounded it to the case and pulled the cord and saw the spark. I tried it with the on/off switch in the off position and no spark, got spark with the switch in the on position. I am wondering though if I am not getting enough fuel into the cylinder.
Also, what size Torx bit do I need to take out the spark arrester screws? It looks bigger than a T-20.
Thanks.
  #4 (permalink)
Old 01-05-09, 09:19 PM
cheese's Avatar
Topic Moderator
Sounds to me like it's flooded, especially if mist is coming out the plug hole. I think you have a carb problem still.
__________________
God bless!
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
