cancel
Go Back   DoItYourself.com Community Forums > Cars, Trucks, RV's, Boats and Outdoor Power Equipment > Outdoor Power Equipment and Small Engines
Outdoor Power Equipment and Small Engines Lawn, Yard, Garden and Shop Gasoline Engine Powered Machinery.
Thread Tools Display Modes
  #1 (permalink)
Old 12-03-08, 03:40 PM
Toro 524 wont go into gear
I have a Toro 524 model 38040, and the other day it stopped moving. I can shift it into any of the gears, but it doesnt do anything. What could it be? Thanks, Dan
  #2 (permalink)
Old 12-03-08, 05:37 PM
could be a couple of things.
1). worn or loose belt
2). worn friction drive disc
3). worn wheel axle bushings
To check for worn wheel axle bushings, lift & hold the wheels off the ground(put a block or stands under the lower pan) . Push up on the tires. If the whole axle moves up, you need to replace the axle bushings.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
