| Is it in neutral - the tranny free wheels with the clutch out? If so, the light is just an indicator of the circuit continuity to allow starting. You can go down to the safety switch on the tranny and see if it has came loose from the casing or possibly a wire connection is causing a problem. If all is well there, the switch could be at fault. Once you have it in neutral, that's about all the shift linkage has to do. |
