cancel
Go Back   DoItYourself.com Community Forums > Cars, Trucks, RV's, Boats and Outdoor Power Equipment > Marine: Boating, Sailing, PWC, GPS and Navigation
Marine: Boating, Sailing, PWC, GPS and Navigation Power Boating, Sailing, Personal Water Crafts, GPS and Navigation.
Thread Tools Display Modes
  #1 (permalink)
Old 07-03-09, 12:59 AM
Happy Face spray on bedliner on boat
Anybody tried spray on bedliner on boat to protect from rust and chemical corrosion.I have applied spray on bedlier recently.What you say?
  #2 (permalink)
Old 07-03-09, 05:22 AM
Welcome to the forums.
I wouldn't consider using it on the hull but see no reason why you couldn't use it on the deck.
  #3 (permalink)
Old 07-03-09, 09:15 PM
A lot of folks in the mountain west are putting it on drift boats for fishing rivers. Keeps them from getting dinged up from hitting rocks. I wouldn't recommend it for any hull you want to plane.
Mike
  #4 (permalink)
Old 07-04-09, 04:40 AM
spray on bedliner
I would not put it on the outside, below the warter line, inside would be fine.
  #5 (permalink)
Old 07-14-09, 04:54 AM
I sprayed qwikliner spray on my boat.It prevents boat from chemical corrosion,rust,scratches.My boat looks like newone.
  #6 (permalink)
Old 07-28-09, 06:01 PM
I have a bayliner with tired carpet and I am planning to go the same route, pull it up and have a thick blue liner sprayed on the floor...
My buddy had his truck done and he hauls gravel, rocks, really beats that bed, and it's held up well for a couple years now.
Probably the hardest part is you'll have to remove or mask off whatever you don't want covered very well, overspray is not coming off.
  #7 (permalink)
Old 08-11-09, 02:29 PM
I have talked to a couple guys that did this to thier boats. They were not happy with how HOT the deck got. Feel the back of a pickup and feel how hot the deck gets compared to carpet in the sun.
  #8 (permalink)
Old 08-11-09, 02:35 PM
Gunguy45's Avatar
Topic Moderator
Well of course..if you do black...there are plenty of other colors. And you can always put carpet or mats on top.
__________________
Vic
I'm no expert, but don't tell my wife that.
  #9 (permalink)
Old 09-07-09, 02:33 PM
Be sure you do not EVER want to get it off. I am restoring an ElCamino that had one sprayed in it, i was successful in removing it, with a die grinder and rust stripping wheel, would not want to try to remove that stuff from fiberglass!!
  #10 (permalink)
Old 09-07-09, 02:58 PM
Gunguy45's Avatar
Topic Moderator
Thats why the good ones have a "no peel" warranty. Gotta tell ya..when I saw the guy going at the bed of my brand new $24K Dodge truck with a wire wheel on a grinder..it kinda made me worry...
They did that and then wiped everything with something (paint thinner? acetone?) and did the spray after masking.
8 years of no issues at all...at least with the bedliner...
This was Line-X..I just like it better than the Rhino.
__________________
Vic
  #11 (permalink)
Old 09-18-09, 11:31 PM
liner spray
What I see with liners is tool boxes slide all over the back...does the spray do the same?
  #12 (permalink)
Old 09-19-09, 07:37 AM
Gunguy45's Avatar
Topic Moderator
hvac...some liners do let things slide, yes. But no more than bare metal or the drop in liners..maybe a little less. Rhino is actually much less likely to let things slide around from what I've seen.
__________________
Vic
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
