cancel
Go Back   DoItYourself.com Community Forums > Exterior Home Improvement Center > Lumber and Siding
Lumber and Siding Lumber, Paneling, Wood Shake, Brick, Stone, Slate, Stucco and Aluminum Sidings.
Thread Tools Display Modes
  #1 (permalink)
Old 10-31-09, 11:30 AM
Panel choice - Stiff - light -
I am making an outdoor project that needs to survive the weather.
I need a stiff (about 1/4") panel.
Weight and stiffness are the major concerns.
I looked at a PVC panel, but it is too flexible, a shower stall type board is too heavy, corrugated plastic panels, are too weak.
Any suggestions??
Thanks
David
This is for the ground board for a telescope that will live outside in the weather. Normally I would use plywood, but it won't survive living outside.
Hope this forum is appropriate.
  #2 (permalink)
Old 10-31-09, 02:37 PM
Topic Moderator
davisdpixx
Welcome to the forums.
A more in-depth description of what you are doing and what you need would be helpful, but I'm assuming that you need a platform to mount your telescope on.
Something along the lines of a PVC panel (lexan is stronger than PVC, but still flexible) on a grid of supporting joists??
  #3 (permalink)
Old 10-31-09, 04:52 PM
chandler's Avatar
Agree, Lexan in 1/4" will be a little pricey, but if it is a permanent mount for the scope, you will certainly fasten it down. Predrill your holes and use stainless screws with stainless washers. Fastening the scope to the lexan and deck should go through all layers, as the lexan may not be able to keep it from tilting in high winds without cracking.
  #4 (permalink)
Old 11-01-09, 04:16 PM
Panel choice.
Thanks all. I will try the PVC.
David
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
