cancel
Go Back   DoItYourself.com Community Forums > Electrical and Electronics > Lighting, Light Fixtures, Ceiling and Exhaust Fans
Lighting, Light Fixtures, Ceiling and Exhaust Fans A/C & D/C Electrical. Lamps, Recessed, Track, Fluorescent Lighting, Outdoor Yard/Patio, Direct, Indirect, Flood, Spot Lighting, Whole House and Attic Exhaust Fans.
Thread Tools Display Modes
  #1 (permalink)
Old 01-21-09, 05:02 PM
Bathroom Exhaust Fan Recommendation?
I am replacing a very old noisy bathroom exhaust fan. It's a 1/2 bathroom that has a toilet and a sink, It's 4.5 ft by 5 ft by 8 ft height (approx 180 sq. ft. total). Since it's 1/2 bath, I'm not worry about mirror fogging up from the shower, just... um... get rid of the aftersmell once the user done his deed .
Several questions:
What is the recommended CFM speed for the bathroom size and quick evacuation of the smell?
I'm looking for whisper quiet (it's ok that it's barely humming) fan. Will 1.5 sone be sufficient or at most 1?
Any fan recommendations that are bang for your buck?
  #2 (permalink)
Old 01-21-09, 06:50 PM
Here's the sizing chart. I can't help you with the sound level. I replace our old noisy ones with a 3 sone rebuild kit from Home Depot. Much quieter than the old ones but likely louder than your taste. Personally I prefer at least a little noise from the fan as long as its not annoying
How to properly size a bathroom ventilation fan
  #3 (permalink)
Old 01-22-09, 08:20 AM
I like a fan with some noise. Otherwise my family forgets to turn it off and leaves it on all day and it sucks all that expensive conditioned air out of the house.
  #4 (permalink)
Old 01-22-09, 08:34 AM
Topic Moderator
The other soluation is put in a wall timer or motion sensor both work very well and they will shut off automatically after so many of X minutes.
Merci,Marc
__________________
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?)
  #5 (permalink)
Old 01-22-09, 08:41 AM
Can't go wrong with Broan fans, relatively inexpensive and made in the US. I installed a wall fan recently based on the 5 star rating at amazon and wasn't disappointed.
  #6 (permalink)
Old 01-27-09, 10:00 AM
Thanks for the tips and suggestions guys. Ha ha, maybe I will get one with a little noise so it's not dead silent. I see alot of the fans are at least 50cfm which is more than enough for the small 1/2 bathroom. Most of the ones I like so far have the cutout opening like around 8"x10" or even 10"x10". I think mine is like 7"x7". I guess I need to open it up more.
  #7 (permalink)
Old 01-27-09, 10:16 AM
consider panasonic bathroom fans - they are super quiet and move a lot of air. we recently replaced the stock Broan fans our builder put in and we are much happier. we put a timer on the wall so we can leave the fan on a bit after showering and not have to worry about turning it off.
  #8 (permalink)
Old 10-24-09, 05:09 AM
Remove Stale Air from Near the Floor
I learned that the more poisoned air is closer to the floor. The baddie is hydrogen and hydrogen compounds (hybrides of hydrogen.) Some of these are called nitrosamines, and these and many others are found in indoor air.
Typical bathroom and ventilation fans have a cover that "sips" air from the ceiling position, and keeps it from removing air near the floor. Air wants to striate, like taffy, and you can see it making a coherent stream in many situations of air being moved, vertically or horizontally.
In an apartment I had, I made a tube from cardboard and covered it with white paper for looks. I installed it on their fan instead of the plastic cover, and found that the air was being moved from the floor area almost immediately when turning it on.
This gave a great benefit in freshness, and I used it regularly just to keep the place nice.
  #9 (permalink)
Old 11-07-09, 03:27 PM
exhaustedkitty's Avatar
Miloo,
Recommended size with all manufactures 1cfm per sq. foot. But please remember...no matter how powerful the fan is, you NEED makeup air. A window cracked a door...if not an option, slice a little off the bottom of door..you can't exhaust it out unless you bring it in.
1.5 sones is pretty quiet. Broan has one that is quieter than the quietest Panasonic.....
.3 sones..Which is the fan I would recommend..qtxe080 or the Nutone equivelent qtxen080 (they bought each other out)
ATTENTION ALL PANASONIC LOVERS:
Other than the fact they are made in china...years down the road (or 3) when the motor goes out, good luck getting replacement. Over the years, Panasonic changes the models just enough so that you HAVE to tear out the old housing and cut to install new..pretty spendy depending on your ceiling.
Just wanted every one to know what most people don't
Tags
bathroom, ceiling, exhaust fan
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
