cancel
Go Back   DoItYourself.com Community Forums > Electrical and Electronics > Lighting, Light Fixtures, Ceiling and Exhaust Fans
Lighting, Light Fixtures, Ceiling and Exhaust Fans A/C & D/C Electrical. Lamps, Recessed, Track, Fluorescent Lighting, Outdoor Yard/Patio, Direct, Indirect, Flood, Spot Lighting, Whole House and Attic Exhaust Fans.
Thread Tools Display Modes
  #1 (permalink)
Old 11-22-08, 12:59 PM
Replacing Lamp Switch
hi, I have lamp that had a dimmer switch that stopped working. So, I got a replacement. The replacement is a push-through switch.
The issue is that the new switch has the terminals for the wires on the side, but the original had them on the bottom.
So, the cardboard and metal sleeve that goes over it tightly fits over the switch, touching the screws on the terminals.
I'm assuming this is not ok, if anyone could validate (or invalidate) that, it would be much appreciated.
I replaced it and turned it on just to test the switch and it worked (its now unplugged until i know if its safe or not).
thanks in advance.
  #2 (permalink)
Old 11-22-08, 01:16 PM
Well if you have the metal casing insulated from the connections then you are sort of ok.If they ever wear through the cardboard you will get a connection and maybe get shocked or a burned switch etc.The real way to make sure you're good is to replace the entire switch casing and all not just the inner part.
Over the years different manufacturers put the contacts at different points on the socket.Some side some bottom etc.Generally the outer casing was manufacturered to fit that particular set up and a different design may not fit well enough to be safe.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
