| Defrost problems Well, I took everything apart today. Put the fridge in forced defrost mode. Disconnected the defrost heater and measured 120V! Measured the defrost heater at 33 Ohms. But when i put the connectors together, no heat. At this point the only thing that makes any sense to me is that the pins are not making contact within the connectors. So, I connected one side and measured 120V across the other side. When I reconnected the second side and opened up the first, I get 120 Volts. This does not make any sense to me at all. Anyone have any ideas? At this point, I am considering cutting out the connectors and soldering the wires together to see if that helps. I would appreciate any ideas. Thanks. |
