Remove the icemaker and check for a partially frozen fill tube, you can thaw it with a hair dryer.
If ok, swap the rear water solenoid electrical plugs,press the water dispencer for 9 to 14 seconds and see if the icemaker mold fills up. If not, you either have weak water pressure to the water solenoid, or a bad solenoid.
