cancel
Go Back   DoItYourself.com Community Forums > Household Cleaning, Kitchen Appliance Service and Repairs > Kitchen Large Electric Appliances
Kitchen Large Electric Appliances Service and Repair Advice. Stoves, Ranges, Ovens, Broilers, Grills, Dryers, Refrigerators, Dishwashers.
Thread Tools Display Modes
  #1 (permalink)
Old 11-30-08, 05:39 PM
Question Kenmore Dishwasher emits high pitched noise
I have a Kenmore dishwasher - model #665.13834K600 that emits a high pitched noise during the wash cycle. Any ideas how tp fix the noise?
  #2 (permalink)
Old 12-01-08, 08:42 AM
Has this problem been this since you owned it, or has this problem later begun so you know it is not factory bad design?
Other than cleaning out your sump down where the screen guard is and removing all debris to perhaps eliminate something narrowing the holes that may be creating a whistling effect, I can't imagine it being anything simple other than that.
Maybe motor or pump bearing is starting to go out? Access toe-kick panel (often 2 screws on both the panels, and make sure no water leaking out under pump onto floor. Keep an eye on problem and see if it gets worse.
  #3 (permalink)
Old 12-01-08, 12:11 PM
Thanks. Machine is approx 5 years old. Likely not an easy fix
Tags
mbrent001@tampabay.rr.com
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
