cancel
Go Back   DoItYourself.com Community Forums > Household Cleaning, Kitchen Appliance Service and Repairs > Kitchen Large Electric Appliances
Kitchen Large Electric Appliances Service and Repair Advice. Stoves, Ranges, Ovens, Broilers, Grills, Dryers, Refrigerators, Dishwashers.
Thread Tools Display Modes
  #1 (permalink)
Old 11-21-08, 09:10 AM
Unhappy washing machine wont empy
Hi i have a frigidare washing machine when it gets to the empy cycle it wont empty out.I checked the lines and the water does come out when i disconntected the hose on the bottom of the washer.Whould it be possebly that small motor that the water goes through?
Thanks For your help in advance
Barry taylor
  #2 (permalink)
Old 11-22-08, 01:48 PM
pugsl's Avatar
Topic Moderator
Is this a front loader? If it is take off the water pump and see if something is jammed in impeller. Have found bobby pins and socks in there. Look in rear of pump first and while there, clean out coin trap in hose.
  #3 (permalink)
Old 11-25-08, 06:09 AM
washer
Hi
Its an old model top loader it will wash and fill but it wont empty i checked all the hoses and seems clear.
  #4 (permalink)
Old 11-25-08, 11:09 AM
small motor
i took the small motor out that drains the water i will get it tested tried everything else i can think of
  #5 (permalink)
Old 11-25-08, 11:17 AM
pugsl's Avatar
Topic Moderator
when the pump is in the Spin, drain cycle you should of heard the pump making noise, If not and nothing stuck in inpellor you need a pump. very unlikely but a bad timer could also cause this. Have you checked the lid switch. Not usually a problem with your machine but also something to check.
  #6 (permalink)
Old 11-26-08, 08:01 AM
Hi
Thanks for getting back so soon to me.The machine washes
the clothes and it will start but no water comes out.I checked the impeller it seems to be free and it doesnt make any noise at all.
Thanks again
  #7 (permalink)
Old 11-27-08, 10:44 AM
Hi Muterboys
For testing the pump, this is fairly easy : just plug mains of the motor.
Yu can take off the lid to see the impeller.
If it is not revving, the pump is dead.
If it is revving, I suspect something like a coin is inside the rubber tube between the tank and the pump.
It is a very tricky breakdown.
Good luck!
Marc
  #8 (permalink)
Old 12-02-08, 10:44 AM
motor
Hi
I purchased a new pump motor and put it in and it worked for a week now its stopping agian at the empty mode.the lid switch has been actiing up would this be another cause
HTML code is On
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Content Relevant URLs by vBSEO 3.2.0
