cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Humidifiers and Dehumidifiers
Humidifiers and Dehumidifiers Furnace Installed and Portable Units. Installations, Repairs and Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 01-25-09, 02:04 PM
Question Skuttle Humidifier to Goodman Furnace
I have a Goodman AEPF 4260 Furnace/Heat Pump and a Skuttle Humidifier. Wiring diagram says wires to R and humidistat but whenever I plug it in there's no voltage? :wall:Unhooked I have 24V. There's a jumper that had to be cut and I did that but nothing. Also hooked wire to another terminal and got power but I am afraid to leave it there as it might do damage to board. Thanks for any help.
  #2 (permalink)
Old 01-26-09, 10:53 PM
Jay11J's Avatar
Topic Moderator
Ok, one wire on R and where's the other one gong to?
What was the other letter you hooked up to and got power?
__________________
-Jay
If you can do it, We can help.
  #3 (permalink)
Old 01-27-09, 07:30 PM
goodman furnace, skuttle humidifier
The other terminal is marked humidstat, (supposed to be correct wire). The terminal that gave me power was O.
Thanks
  #4 (permalink)
Old 01-27-09, 09:19 PM
Disconnect and stay away from the O wire. This is your cool active reversing valve. Wire up, from HVAC, terminals R and HUM to the humidifier and then to Humidistat.
  #5 (permalink)
Old 01-28-09, 06:57 AM
yes, those are the 2 I used but no power. I scanned the wiring diagram if I can figure out how to post it, if not can I email to you?
Thanks
  #6 (permalink)
Old 01-28-09, 07:26 AM
Send wiring diagram to:
removed e-mail address, either post it in your profile or spell it out like at dot
  #7 (permalink)
Old 01-28-09, 09:58 AM
goodman furnace/skuttle humidifier
diagram sent. Thanks for the effort!
  #8 (permalink)
Old 01-28-09, 11:42 AM
Jay11J's Avatar
Topic Moderator
I am unable to find a diagram for you unit.
If you know for sure HUM is 24 volts, then other wire goes to C./Com on the board.
__________________
-Jay
  #9 (permalink)
Old 01-28-09, 03:27 PM
goodman
which diagram? I emailed the furnace one. from Removed e-mail address. Put them in your profile or spell it out like at dot com
  #10 (permalink)
Old 01-28-09, 04:22 PM
so one wire to HUM and one to com? Great, thanks a lot Jay!
  #11 (permalink)
Old 01-28-09, 04:53 PM
Jay11J's Avatar
Topic Moderator
Quote:
That is if your HUM is 24 volts. If it is 24volts, then yes.
__________________
-Jay
  #12 (permalink)
Old 01-28-09, 06:17 PM
Goodman Furnace, Skuttle Humidifier
That works! You're the man Jay! the com terminal is the condensor? I measure 24volts either way, does it matter if one is to R and one to com or HUM and com?
  #13 (permalink)
Old 01-28-09, 09:48 PM
Jay11J's Avatar
Topic Moderator
C is common side of the system. And yes, you will have a wire from the A/C. Y from A/C is the "hot" side on call of cool.
R is always hot, that's your power.. HUM powers up when there is call for heat.
__________________
-Jay
Tags
goodman, himidifier, wiring
Smilies are Off
HTML code is On
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
