cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Humidifiers and Dehumidifiers
Humidifiers and Dehumidifiers Furnace Installed and Portable Units. Installations, Repairs and Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 01-14-09, 07:34 PM
Install Help for HE360A on a Nordyne
This is my first humidifier install. I have a 2320 sq. ft. home all laminate wood flooring in Tennessee. Before I start cutting I just wanted to make sure I had the layout the best as possible. A few concerns of mine:
Can I just cut and peel the insulation sleeve where it covers all my template openings?
Am I going to hit anything where I am cutting for my Humidifier?
The sail switch is in an okay position but the humidistat is on a cylindrical return tube. Will I still be able to form a seal when I mount the humidistat on this return or should I seek a better location?
Here are a few pics: Overall layout, humidifier location, humidistat location, sail switch location.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
  #2 (permalink)
Old 01-15-09, 02:52 PM
Jay11J's Avatar
Topic Moderator
Quote:
Yes, you are OK with that lay out. I would do a dry fit of the unit itself up on the supply duct to see if the lines, and PVC pieps clears it.
No, you are in the clear. The A/C oil is in the box below.
I would put the humidistat in the duct above the round return drop.
Sail switch, you may have a good chance not not be needing that.. We could wire it to the furnace, but what is the model # of the furnace?
A couple of things caught my eyes, and how old is this furnace?
-I see there is no pipe going outside for the burners, was there one or not?
-The Exhaust pipe is done wrong, and I'd strongly suggest on getting that fixed.
__________________
-Jay
If you can do it, We can help.
Tags
he360a, humidifier, installation, location, nordyne
Smilies are Off
HTML code is On
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
