Hi there,
I am trying to install my forced air flow through humidifier. The problem I am having is that the way my return duct is placed I only have 8 inches to screw it on - not making it wide enough to install the unit onto.
I can install it on the side of the return air duct. The problem then is that the tube passing from the humidifier to the supply duct will be uneven.
Check out the illustraton on page 2 and you will see what I mean:
http://www.airkinglimited.com/airkin...s/AK7000IO.pdf
My question is: if I install the unit higher than the connection into the supply duct - will the unit not be effective, or will the difference be minimal.
Any advise is appreciates.
