| Humidifiers and Dehumidifiers Furnace Installed and Portable Units. Installations, Repairs and Maintenance, Services and Technical Advice |
11-18-08, 07:34 PM
Humidifier selection/install questions
I am looking to install a humidifier in my home.
My home is 3,000 sq. ft. and was built in 2004.
1) What size of humidifier should I purchase, small (12-16gpd)or large (18gpd)?
2) Should I purchase a fan powered unit or bypass unit, currently, the home has Carrier furnace model 58STA & Carrier central air unit model 38CKC
3) Regarding installation, should the humidifier be mounted on the return-side or the supply-side?
4) Is installation relatively easy for a do-it-yourselfer?
11-18-08, 07:46 PM
Topic Moderator
Quote:
With that new of a home, i'd say the 12-16 gpd should be enough.
I perfer the bypass unit, less things to go wrong.
Bypass unit is best on return side, if you don't have room on the return side, and have room on the supply you can do that.
Guess on how good you are.. It can be easy if you are good with working and cutting metal.
Wire should be easy for your furnace since it has 24v hook up for the humidifier.
__________________
-Jay
If you can do it, We can help.
11-19-08, 08:44 AM
Add'l questions
Thanks for the response, Jay
Now, for the million dollar question: where can I get one online? The only website that I've come so far is GoGeisel.com
Also, I was thinking about sticking with Carrier branded product, are Carrier humidifiers reliable or should I look at others such as Aprilaire, Honeywell, etc...
Thanks in advance
11-19-08, 03:50 PM
Topic Moderator
Carrier is just a rebranded Aprilaire humidifier, and paying more for the Carrier name stuck on the cover.
They are all the same. I never came across any issues with any brands. I have the Honeywell, my parents got the Aprilaire/Trane.. You can get the Honeywell at Home Depot or other Home Centers.
__________________
-Jay
11-19-08, 07:43 PM
Would I have any issues connecting a Carrier Thermidistat control to an Aprilaire 500A or Honeywell HE220 and a Carrier 58STA furnace?
11-19-08, 08:02 PM
Topic Moderator
Nope. Anything will work.
__________________
-Jay
| Thread Tools |
| Display Modes |
Linear Mode
| Sign up for our FREE newsletter! Find Qualified Local Contractors
Sponsored Ads
