cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Humidifiers and Dehumidifiers
Humidifiers and Dehumidifiers Furnace Installed and Portable Units. Installations, Repairs and Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 11-02-08, 09:41 AM
Honeywell 220 to Goodman
Hey guys! I just picked up a Honeywell 220. I've read a lot on here about trying to wire directly to the furnace board if possible.
I have a Goodman ARUF023 model. I pulled the front panel and did not see any "hum" or any other promising looking spade terminals.
Does anyone know about this furnace model? Am I stuck using a sail switch. Of course I was trying to not have to use the 120 transformer which will require me to wire up an outlet near by to plug into.
Any advice?
Thanks!
  #2 (permalink)
Old 11-02-08, 06:44 PM
Jay11J's Avatar
Topic Moderator
This is not a furnace, it is an air handler for heat pump w/ electric heat back up.
There is no hook up on here for the humidifier.
You are kinda stuck with the sail switch, but there is another way we can wire it.
you can wire it from G wire at the air handler to the humidistat. Humidistat to humidifier.. humidifier back to the air handler's C.
__________________
-Jay
If you can do it, We can help.
  #3 (permalink)
Old 11-03-08, 10:37 AM
I realized when I started more research on this model that it was referred to as an air handler. Furnace is just my generic term for it all since I don't know much about it.
So if I wire it that way, it'll give me my 24v from the G wire? Would I just get a new spade connector and put both wires into the same connector and back onto the G post? When would this tell the humifier to turn on, whenever the heat is on?
I have everything installed so far except the sail switch. So this would still be possible without any patching work.
Thanks for your help. I've read a lot of posts on here and you always seem to provide very good advice. Thanks!
  #4 (permalink)
Old 11-03-08, 11:13 AM
Jay11J's Avatar
Topic Moderator
G is for fan. so any time the t-stat calls for anything, G will power up to run the fan, then that will power up the humidifier.
No, you won't need the sail switch, if you already got it cut in, then go ahead and use it if you want.
You are very welcome.. Glad to help.
__________________
-Jay
  #5 (permalink)
Old 11-03-08, 11:18 AM
Great! The sail switch isn't mounted so I'm good!
I'll just stop and pick up a few spade connectors rather than a new receptacle, yellow wire, box...etc!
I should be good to go then! I forget what the wiring on the humidistat and humidifier look like, but I'm assuming it'll be pretty obvious which one is the hot going into each one and should be the line from the G terminal. If not, you'll see me again!
Thanks!
  #6 (permalink)
Old 11-03-08, 11:25 AM
Jay11J's Avatar
Topic Moderator
With low voltage, there is not right or wrong side to wire..
Wire like this below..
G---humidistat-----humidifier----C
__________________
-Jay
  #7 (permalink)
Old 11-03-08, 11:33 AM
Ok, sounds pretty much like a no brainer. Hate that I paid 70 bucks for this install kit and all I'm using is the ducting, tubing and wiring.
One last question....should I be using the brass inserts into the tubing and then the plastic or brass ring thingy's. Seems like the one side to the humidifier where I used the brass insert it has a slight leak.
  #8 (permalink)
Old 11-03-08, 11:38 AM
Jay11J's Avatar
Topic Moderator
I hate to say this, I hate those "plastic" water lines.. Get the copper ice maker lines instead. I've seen one too many leaks/water damage caused by these lines.
But, yeah you must use those insert to "support" the hose under compression ring
__________________
-Jay
  #9 (permalink)
Old 11-03-08, 11:44 AM
Man...that install kit seems to be more and more useless LOL.
I have a buddy who does pipefitting...I'll probably have him help me just install a true T-joint too instead of the saddle valve.
Guess I'll do the wiring and make sure everything with the plumbing is snug and correct and test her out. Then plan to switch to copper piping and tubing.
What about a flexible hose like used on toilets and sinks? The stainless braided ones?
  #10 (permalink)
Old 11-03-08, 12:08 PM
Jay11J's Avatar
Topic Moderator
Yeah, I did not get the kit for mine when I put mine in.
Good ideal.
Here is mine.
OMG are you kidding me!? You might as well leave the roof off of your house!
Just kidding! Those are fine.. They are braided, so that gives a better support, and got a true fitting on the ends.
__________________
-Jay
  #11 (permalink)
Old 11-03-08, 12:13 PM
Good lord how many shutoffs do ya need!?
Or is the first one a pressure regulator?
I wonder about that on mine...perhaps I have my water pressure cranked too high. Just cranked it up a few weeks ago to get a little more gusto out of my shower and sprinklers.
I'll have to hit the plumbing dept though! I like the setup!
  #12 (permalink)
Old 11-03-08, 12:40 PM
Jay11J's Avatar
Topic Moderator
LOL One is not enough.
No, you are right it's a regulator.. The first year we had it, it drove my partner nuts with the hissing water, and he would crank the valve down to almost no water flow on the humidifier. So I added that last year, and all is well!
__________________
-Jay
  #13 (permalink)
Old 11-03-08, 04:27 PM
I think I've done it!
I've turned the fan on....and when I switch the humidistat above 40 it clicks and I can hear the water flowing. So far I have no leaks, but I am going to switch it to copper t-junction and copper tubing just to be safe.
Its been warm here so the heat hasn't kicked on at all....but it seems to run correctly and nothing is burning or smoking!
You rock man! I like the pressure reg idea though, may go ahead and put one in just to be safe.
I also put in a new filter and one of those gel pads for the scent on the filter...my house now smells like cinnamon and I"m about to puke....woah strong!
  #14 (permalink)
Old 11-03-08, 04:44 PM
Jay11J's Avatar
Topic Moderator
Great!
Yeah, it been warm here today too, had a record high of 74˚
Try it with out it.. They are not cheap!
My mom did that once, I about fell over when I walked into the house..
After that she only put in 1/4 of it intead of the whole thing.
__________________
-Jay
  #15 (permalink)
Old 11-08-08, 01:53 PM
I lasted about 10 hours with that gel insert and it went in the trash.
Quick question for you....everything is running great....but it seems like I'm having an awful lot of water coming out the drain. Once it kicks on, within 10 seconds a decent stream starts coming down the drain.
Maybe too much water pressure? Seems like such a waste of water.
Should I try closing the valve a little maybe so less water enters the humidifer? I'm not sure how much is actually draining each time, but man it seems like more than it should.
Its certainly not a drip drip like an AC unit.
  #16 (permalink)
Old 11-08-08, 06:21 PM
Jay11J's Avatar
Topic Moderator
The unit will use about 2-3 gallons of water an hour if it ran non stop.
Do not shut down the valve, it is normal for the water to flow like this.. It's keeping the pad clean, and adding humidity into your home.
__________________
-Jay
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Content Relevant URLs by vBSEO 3.2.0
