cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Humidifiers and Dehumidifiers
Humidifiers and Dehumidifiers Furnace Installed and Portable Units. Installations, Repairs and Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 12-21-07, 12:42 PM
White Westinghouse WST7503 - Need manual and/or help
Hello
I have a WST 7503 portable humidifier and have misplaced the manual. I cannot get the humidifier to work. It powers on, and when I increase the humidity control, it cranks up for about 30 seconds and stops. I don't have the manual and am not sure if I need to do something else to make it work properly. The thermostat reads at 30 for current humidity. Does anyone have a manual to send me or suggest what I need to do to make it work correctly?
thanks in advance!!..Happy Holidays!
  #2 (permalink)
Old 12-21-07, 04:46 PM
Jay11J's Avatar
Topic Moderator
I am not able to find anything related to your unit other than the replacement pad.
Is this a manual control or digital?
__________________
-Jay
If you can do it, We can help.
  #3 (permalink)
Old 01-11-08, 08:01 PM
I have the same model and am getting an "Er" message and am not sure what needs to be done to remedy. Missing manual as well... so that might be a good start. any help is appreciated. thx in advance.
  #4 (permalink)
Old 01-12-08, 06:08 AM
Jay11J's Avatar
Topic Moderator
Not able to find a manual for this.. Does this Error not go away after the unit has been unpluged?
__________________
-Jay
  #5 (permalink)
Old 01-12-08, 06:19 AM
no. but if I blow on the sensor it temporarily goes away and registers the humidity and allows me to let it run. But after a few secs or minutes, it comes up with the "Er" again which turns itself off. Need to find a way to bypass the sensor since all I really want it for the fan to blow when I have it on.
  #6 (permalink)
Old 01-12-08, 06:27 AM
Jay11J's Avatar
Topic Moderator
Sounds like the sensor may be defective...
Not sure if it's worthwhile trying to find replacement part for it or not?
__________________
-Jay
  #7 (permalink)
Old 01-27-08, 07:05 PM
I was just shopping online for new wicks and I came across this post. I uploaded the manual here probably temporarily.
http://home.members.winisp.net/temp/...503_Manual.zip
Cheers,
Paul
  #8 (permalink)
Old 03-13-08, 06:27 PM
The ER message on the Westinghouse WST7503 Humidifier
We just bought of these and it worked for maybe two weeks
and then quit. The message on the LCD window said ER.
The manual, under Trouble Shooting, does not address this
particular error. I see that I am not the only one that has
had this problem, but do not see what can be done about
it since the manual doesn't say either. Did anyone ever
find out what that means and what can be done about it?
Thanx! Simone
  #9 (permalink)
Old 03-13-08, 06:35 PM
P.S. The link that pandrew posted with the owner's manual
still works and I have compared it to the manual I have and
it is the same - it also does not address this particular error message.
Smilies are Off
HTML code is On
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
