| Home Plans And Home Designs Interior and Exterior Home Construction, Building Plans and Design, CAD and 3D Home Design Programs. |  10-20-09, 01:08 PM | | Member | | Join Date: Oct 2009 Location: Texas Posts: 2 | | | Metal Stud vs. Wood Stud Framing I am working on a project right now that is pretty simple in plan. It is a stage, which has a balcony on the second floor and clock tower above the balcony. The stage is 3'-0" above ground level, the second floor is at 19'-0" above FF, and the eave of the clock tower is at 42'-6". The dimensions in plan are 23'-0" x 23'-0" for the main stage building. There are 4 nearly identical buildings, two on each side of the main stage, that are 16'-0" x 16'-0". Each of these buildings is essentially four walls with a roof. I have the plans, elevations, and sections drawn up as if it were a metal stud building. I would like to get more insight on if the metal studs are necessary/if wood would be more economic, and if there needs to me more structure to the building other than the framing and roof. Thanks! Last edited by pmgca; 10-20-09 at 03:49 PM. Reason: Solicitations are not allowed |  10-20-09, 04:02 PM |  | Topic Moderator | | Join Date: Mar 2003 Location: CA Posts: 2,165 | | Studio11Eleven, the first thing you should check is what is signed in your building permit. Other than this, you should check with the engineer and / or the BD Keep in mind that this Forum is intended to provide help the DIY users, for DIY questions Certainly, solving issues with calculations / structures or number of studs don't qualify as a DIY problem . As a professional, you know that in these situations, you should check with an engineer, right?.... __________________ Good luck with your project! Patricia |  10-20-09, 11:42 PM | | Member | | Join Date: Oct 2009 Location: Texas Posts: 2 | | | I understand that this is intended for DIY's, which is the case here. I'm drawing everything up before building, and my situation does not require following building permits or ordinances. I would move forward with either the wood or the metal studs if I can get confirmation from someone who may have the experience in construction. Thanks. Last edited by pmgca; 10-21-09 at 05:52 AM. |  10-21-09, 04:45 AM |  | Member | | Join Date: Dec 2005 Location: Young Harris, Georgia USA Posts: 13,615 | | | I have experience in construction, and I don't see how this size of structure won't need permits, nor how it won't fall under some sort of local ordinances. It is big. Almost like a city block. I don't care if it is just a "stage", there are pitfalls in building structures of this size. Definitely get engineers involved in this, as they can put their **** on the line when it comes to liability. I have built with both wood and metal, and find metal slower to fabricate, and considerably more expensive. I am old school and still don't trust metal studs for structural stability, which I am sure is unfounded. Just my opinion. |  10-21-09, 05:51 AM |  | Topic Moderator | | Join Date: Mar 2003 Location: CA Posts: 2,165 | | Quote: Originally Posted by Studio11Eleven if I can get confirmation from someone who may have the experience in construction. | I am an experienced (almost 29 years) Architect, and this is my advice--> check with an Engineer __________________ Good luck with your project! Patricia | | Thread Tools | | | | Display Modes | Linear Mode | Posting Rules | You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 10:57 AM. | Sign up for our FREE newsletter! Find Qualified Local Contractors Sponsored Ads |
