Removing a stuck pneumatic cylinder I have an office chair where the pneumatic cylinder was losing pressure when I sat on it. The chair is over 7 years old. I called the manufacturer for advice and they sent me a new pneumatic cylinder at no charge to install. Instructions were pretty simple: remove the base (easy to do); tap the seat mechanism with a hammer while pulling on the existing cylinder - the hammer taps were to create a vibration that would allow the seal to break so the cylinder could be pulled out. Well, it didn't budge. I pounded harder and tried to pull harder. Still no luck. I removed the seat mechanism from the chair and proceeded to see if I could get the cylinder to turn using a pipe wrench. I sprayed WD40 on both ends in the hope that would help loosen it up. No luck with that either. I was able to get a steel rod on the base end of the cylinder and pounded on it with a mini sledge. It seemed to move a fraction but still wouldn't submit to pulling, the pipe wrench, and yet more pounding. I then proceeded to drill a 1/4" hole thru the cylinder (which let all the air or whatever out along with some black gooey stuff). I then put a steel rod thru the cylinder and tried to exert pulling force using that. No luck. I thought an extractor of some sort might work, but I don't have one. Given all that I've tried, does anyone out there have any suggestions on how I might get this thing out so I can install the new one? Thanks in advance for any and all advice. |
