Quote:
Originally Posted by pmgca I don't think this is a good advice: you can't dispose entire tires, for several reasons, includings gas, air cavities and contamination. In addition the whole tires don't provide stability due the air cavities Usually, there are companies that crumb rubber from whole waste tires, and this is a material you can use |
I disagree. I have used this method a couple of times. My grandfather thought it to me. And the foundation we built for his tractor shed 30+ years ago has not budged since we built it.
A couple points I can stress here that are important to this type of building.
• you have to ensure that you pack the sides of the tire first befor the center. This eliminates the air pocket issue if you take the time to do it right and make sure there are no pockets
• there is less environmental impact from doing it this way than taking it and getting it crumbled.
• tires release little to no palutants as they break down. And we all know how long that takes to happen we actually we don't really heh.
• another point is that tires after being cleaned can and are safely used as drinking well liners. Its a something a professor from AZ developed to help in disaster areas both in the US and in other countries. He did the full environmental impact analysis and found that the tire releases less palutants than the standard steel pipe used for wells.
I think that the biggest problem folks have is the actual idea of the nasty looking tire itself. There are plenty of ways to mask or hide them I used local stones to do this myself.
I would ask that you try and pack 1 tire and see how it goes using the method I suggested .
Ps I am not suggesting this use for a house. But a shed or garage type area and I also maintain the checking with the local building inspector is best and that anything over 12x12' should be supported with piers/footings
