| Gas and Oil Home Heating Furnaces Forced Warm Air Furnaces with Registers - Natural & Propane Gas, Fuel Oil, Coal and Wood Burning Heating Systems. Installations, Repairs, Maintenance, Services and Technical Advice |  08-06-09, 03:41 PM | | Member | | Join Date: Dec 2007 Posts: 17 | | | what is a fair price for removing and replacing oil tank in basement? Hi, I have a pin hole leaking my oil tank and need to get it fixed/replaced. I was quoted $1700 to remove and replace a 330 gallon oil tank in my basement. Is this a fair price. I have a hatch to my basement so removal would be relatively easy. Also I noticed a couple of people selling oil tanks for $50 on craigslist. My installer said he would put it in if I buy it. Is this a good idea? it would save me about $450 but it wouldn't be guaranteed. |  08-06-09, 04:00 PM |  | Member | | Join Date: Mar 2005 Location: Minnesota Posts: 4,483 | | | It also could cost a bit to get rid of the old tank legally, since it cannot be just be dumped somewhere at night. |  08-06-09, 04:06 PM | | Member | | Join Date: Dec 2007 Posts: 17 | | Quote: Originally Posted by Concretemasonry It also could cost a bit to get rid of the old tank legally, since it cannot be just be dumped somewhere at night. | good point, I assumed that the price includes disposal of the oil tank. Wouldn't he mention if that was an extra charge? |  08-06-09, 07:24 PM |  | Topic Moderator | | Join Date: Jan 2005 Location: Delaware, The First State Posts: 9,916 | | | Tank Replacement That price sounds reasonable. You might want to ask how much more for a Roth tank. __________________ Work is for those who don't know how to fish.  Grady |  08-06-09, 09:11 PM | | Member | | Join Date: Feb 2007 Location: Brantford Ontario Canada Posts: 98 | | | That doesn't sound out of line to me. |  08-06-09, 09:45 PM | | Member | | Join Date: Dec 2007 Posts: 17 | | Quote: Originally Posted by Grady That price sounds reasonable. You might want to ask how much more for a Roth tank. | thanks, what is the benefit of a Roth tank and how much more should it cost? |  08-07-09, 05:01 AM |  | Topic Moderator | | Join Date: Jan 2005 Location: Delaware, The First State Posts: 9,916 | | | Roth Tank The Roth is rust proof because it is a plastic tank in a metal enclosure & carries $1million in clean up insurance should it leak. Usually they are not much more than a metal tank, maybe $100 or so. __________________ Work is for those who don't know how to fish.  Grady |  08-07-09, 05:52 AM | | Member | | Join Date: Dec 2007 Posts: 17 | | | thanks Grady, is there somewhere I can buy a Roth tank online and have my plumber install it or is this something they only sell to the trade. I notice that in doing a simple google search it's very hard to find pricing on oil tanks and the only ones I can find for sale are used on Craigslist. Do you think it's not worth the risk to install someone's used tank? |  08-07-09, 07:02 AM | | Member | | Join Date: Dec 2007 Posts: 17 | | | wow, I just called a plumbing supply store and the Roth was quoted at $1k and the Granby at $379. Are you sure it should only be $100 more? |  08-07-09, 08:15 AM | | Member | | Join Date: Sep 2006 Location: NJ Posts: 49 | | | Roth tank Unless things have changed in the last year or so only registered Roth contractors can install a Roth tank. Getting registered to do so isn't really a big deal though. Although the Roth is twice the price of the Granby (which is a good tank) one step in the installation process can be skipped over, that of pressurizing the tank and having the inspector witness it. That's worth a few bucks. It also eliminates any requirement for containment since that's part of the tank assembly. It also has a leak detector built in. Add to that the 10 year spill insurance and your narrowing the gap in true cost. As far as a used tank? No way unless you can thoroughly inspect the interior bottom for signs of pitting or corrosion. Remember, most tanks corrode from the inside out. |  08-07-09, 07:42 PM |  | Topic Moderator | | Join Date: Jan 2005 Location: Delaware, The First State Posts: 9,916 | | | Roth Tank I just checked one of my suppliers online catalog & find the Roth to actually be slightly cheaper, including the required installation kit, than the same size Granby steel tank. I must admit their price on the steel tank seemed awfully high. I was mistaken about the amount of insurance on the Roth. It is $5 million, not the $1 million I previously stated. The reason the Granby is so high is it is urethane coated to protect from EXTERNAL corrosion, has a 20 year warranty, & $2 million leak clean-up insurance. The catch is the external corrosion. As Heatpro pointed out, most tanks rust from the inside out NOT from the outside in. __________________ Work is for those who don't know how to fish.  Grady | | Thread Tools | | | | Display Modes | Linear Mode | Posting Rules | You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 02:26 PM. | Sign up for our FREE newsletter! Find Qualified Local Contractors Sponsored Ads |
