| Dunkirk Furnace Broiler gas valve not energized? Hi Hopefully someone can help... My Gas boilers furnace Main Burners wont fire. The Cas Valve burner light is OUT> I found a Bird caught in the Vent Damper and the Damper was caught up blocking the vent. I removed the bird and I'm thinking the Blocked Vent Shut off tripped. I think I have found the Flame Roolout, but not sure of the vent shut off? On the diagram it looks like they are right in line. I have found two spots which look to be saftey cut offs. I changed the thurmal couple switch because I had a spare and didn't make a difference. Do you have a pic of the blocked bent safety shut off? I opened the vent and put in manual status to try and fire furnace. Everything else looks OK. Any help would be appreciated. Thanks Lee |
