cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Gas and Oil Home Heating Furnaces
Gas and Oil Home Heating Furnaces Forced Warm Air Furnaces with Registers - Natural & Propane Gas, Fuel Oil, Coal and Wood Burning Heating Systems. Installations, Repairs, Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 11-21-08, 04:12 PM
Question for the pros.
My furnace stopped working the other day and had someone fix it. He replaced the nozzle and the primary controller. Furnace is working. I don't know much about furnaces. But I heard that you are suppose to put the exact same nozzel back in.
Now.
He took out .75 60W and put in a .60 80W. Is this ok?
He then told me that my burner unit was to big for my furnace and he had the one that was suppose to be on there and he would trade me. Is he telling me the truth, or is he tring to pull one over on me?
The furnace was in the house when I moved in.
I would like to thank you for taking the time to read and reply.
Spec.
Furnace
Lincoln Barriere Model: LOA105R Serial: D 2421-9 Burner listed on tag: Riello M3 Nozzle min:.60 max:.75 Spray pattern: 800W. Division of Keeprite Inc.
Burner on it now.
Riello Model:Mectron M5 Serial:T217T Firing rate: .75 - 1.50 Max nozzle size 1.25
  #2 (permalink)
Old 11-21-08, 09:10 PM
Grady's Avatar
Topic Moderator
Burner
Either the Mectron 3 or 5 will work. With the Mec 3, you are at the top of the firing range & with the Mec 5 you are at the bottom. The 80º nozzle is correct at least with the Mec 3 burner & probably ok with the Mec 5.
__________________
Work is for those who don't know how to fish.
Grady
  #3 (permalink)
Old 11-23-08, 11:27 AM
Thanks for the reply.
So there is no good reason to swap out my burner?
  #4 (permalink)
Old 11-23-08, 01:54 PM
Grady's Avatar
Topic Moderator
Changing Burner
If it is & has been running well, leave it alone.
__________________
Grady
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
