| Gas and Oil Home Heating Furnaces Forced Warm Air Furnaces with Registers - Natural & Propane Gas, Fuel Oil, Coal and Wood Burning Heating Systems. Installations, Repairs, Maintenance, Services and Technical Advice |  11-21-08, 11:18 AM | | Member | | Join Date: Nov 2008 Posts: 3 | | | Furnace Efficiency I have recently bought a house (870 sq.ft),1985 built. It is equipped with keeprite furnace as old as house. Being a rookie from other country , where no furnace heating is required, I have no experience. All is working well, but for my own knowledge I wanted to know if this house is insulated well. I have kept the indoor temperature @ 19 degrees. The outdoor temp. now a day is -15 degrees and with the wind chill -25 degrees. The furnace once reaching to set temp., restarts after every 15 minutes, keeps running for 7-8 minutes. I dont know if this is fair enough effeciancy of the house and furnace. Thanks for your advice in advance. |  11-21-08, 09:31 PM |  | Topic Moderator | | Join Date: Jan 2005 Location: Delaware, The First State Posts: 9,916 | | | Furnace efficiency If the exhaust pipe on the furnace is white plastic the furnace is at least 90% efficient. If the exhaust pipe is metal, the furnace is only in the 80% range. Look in the attic for insulation, measure the thickness & post the thickness & type of insulation and we should be able to give you an 'R' value. If the house is over a crawl space or unheated basement, check also the insulation under the floor. __________________ Work is for those who don't know how to fish.  Grady |  11-24-08, 07:45 AM | | Member | | Join Date: Nov 2008 Posts: 3 | | Thanks for responding!! The insulation in the attic is spray foam type with a thickness of +1'-0". The exhaust pipe of the furnance is metal. The basement/lower level of my bi-level house is fully furnished with flooring as slab on grade. Hope you would be able to tell me the R value with this. Thanks in advance |  11-24-08, 09:14 AM | | Member | | Join Date: May 2007 Location: Wisconsin Posts: 6,465 | | | Foam? Where are you located? I am not familiar with spray foam used for attics. I know it is done for walls, but never heard of it for ceilings, perhaps due to a weight factor? But foam will have a far higher insulated rating than fiberglass, which would be R-38, if you had a foot of that. I would not doubt you are around 50, give or take some. |  11-24-08, 01:05 PM | | Member | | Join Date: Nov 2008 Posts: 3 | | | It is actually blown -in insulation, Sorry about my no or less knowledge. |  11-24-08, 03:43 PM | | Member | | Join Date: May 2007 Location: Wisconsin Posts: 6,465 | | | One foot of that real loose white fluffy fiberglass that does not itch, would not be as good as 1 foot of cellulose. So you really need to know what you have. | | Thread Tools | | | | Display Modes | Linear Mode | Posting Rules | You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 11:54 AM. | Sign up for our FREE newsletter! Find Qualified Local Contractors Sponsored Ads |
