cancel
Go Back   DoItYourself.com Community Forums > Exterior Home Improvement Center > Garages and Carports
Garages and Carports Building, Finishing, Additions, Remodeling, Conversions and Workshops.
Thread Tools Display Modes
  #1 (permalink)
Old 11-02-09, 02:52 AM
Side door on garage leaking
Just bought this house and there was a new prehung installed in the garage. (side door). During rain water seaps in around the bottom of the theshold. The theshold sites flat on the garage side, but on the sidewalk side this is a big gape (3/4")
My gut feeling is seal this with some cement patch. But the theshold seems to sit on the cement inside the garage nice and flat. There is a little ridge in the cement under the theshold. Is this suppose to keep the water out? This prehung door has the theshold attached to it, so I can't get to the bottom without removing the door. The question is can I build up the cement on the outside or is the ridge set up to allow ater leave if the garage floods or should it be tight. This ridge I speak of ends about an inch short on covering the theshold gap. This is where the water is getting in.Hope this makes sense.
thanks,J
  #2 (permalink)
Old 11-05-09, 12:59 PM
My guess is that the original door sealed against the ridge on the slanted cement saddle (what you call the threshold). Now that there is a pre hung door with it's own saddle, it's at the wrong angle & that's why you have a gap. Is the ground outside the door pitched away from the door? Is there a rein gutter on that side of the garage? Is a puddle forming during a heavy rain?
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
