cancel
Go Back   DoItYourself.com Community Forums > Exterior Home Improvement Center > Garages and Carports
Garages and Carports Building, Finishing, Additions, Remodeling, Conversions and Workshops.
Thread Tools Display Modes
  #1 (permalink)
Old 07-04-09, 09:31 AM
Angry Genie Garage Door Sensor problem
My garage door will close once the wall opener is held. If it is let go it will retract. I checked the connections on the back of the sensors and found one broke. I replaced the sensors, the green light is on yet it keeps doing the same thing. I have also tried to place something in the line of sight to see if the red light would respond and it does not. I did not need to add any additional wire so it is coming from the same as before. Trying to work on this for 2 days and am almost ready to start using the front door. Very frustrating. Hope anyone can help.
  #2 (permalink)
Old 07-04-09, 10:43 PM
Reset the breaker.
  #3 (permalink)
Old 07-05-09, 05:02 PM
Both lights should be on steady with nothing blocking the sensors. When something blocks the units one goes out, immediately, no delay. I have seen units that the transmitter does not emit fully, LED dim. But you replaced the units so that should not be an issue. Recheck all wiring for poor connections, breaks etc.
What he said. Pull the power for about 30 seconds, then retry.
  #4 (permalink)
Old 07-06-09, 10:52 AM
The wires to the door sensors are color coded. Make sure you hooked them up right.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
