cancel
Go Back   DoItYourself.com Community Forums > Exterior Home Improvement Center > Garages and Carports
Garages and Carports Building, Finishing, Additions, Remodeling, Conversions and Workshops.
Thread Tools Display Modes
  #1 (permalink)
Old 01-11-09, 11:21 AM
Removing old garage floor drain cover
In the middle of our 1949-era cement garage floor there is a round (approx. 6 inch) iron drain cover with small holes in it and the legend "Slop Sink" on it. The drain isn't working and I would like to remove the cover to clear it out. I have tried using a masonry chisel around the edge of the cover, but even removing a 1/4" of concrete around it won't budge it. The cover is quite substantial--even using a sledge hammer on the convex-shaped cover won't dent or crack it. Can anyone advise me about how to remove this cover? I don't know the shape of the unit under it--do I have to remove more of the concrete around it? Other thoughts? (I would rather not pour corrosive or other drain products down the drain, for the drainpipe goes onto the back lawn.)
Thank you.
  #2 (permalink)
Old 01-11-09, 07:04 PM
I think removing more concrete is what you have to do unless you can cut it with a sawzall. Use the Ax blade if you try it.
  #3 (permalink)
Old 01-12-09, 08:19 AM
badeyeben's Avatar
If the drainpipe is visible outside could you clean it out from there? Use the sewer tape from the outside toward the garage?
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
