cancel
Go Back   DoItYourself.com Community Forums > Interior Home Decorating and Design Center > Furniture, Wood and Cabinetry Finishing
Furniture, Wood and Cabinetry Finishing Techniques, tools, products needed for painting, staining, stripping, finishing and refinishing all types of wood, furniture, MDF, melamine, cabinetry, etc.
Thread Tools Display Modes
  #1 (permalink)
Old 11-21-08, 06:40 AM
Stripping risers
Threw out the carpet and had my hardwood floor sanded and sealed.They also did the stair treads only.I'm presently using a heat gun to get the white paint offof the risers.Is it possible to skip this step and just use coarse grit paper and a dremel for the corners? If so,what grit would be best? It's a real***** and time consuming too
Thanks,Dave
  #2 (permalink)
Old 11-21-08, 03:20 PM
Topic Moderator
Before you do too much work - do you know what type of wood the risers are made of?
95% of the risers that I've painted have not been hardwood. Most often pine or plywood. If you really want hardwood/stained risers, you might consider 1/4" oak plywood to laminate over the current risers.
__________________
retired painter/contractor * * avid DIYer
  #3 (permalink)
Old 11-30-08, 04:39 PM
risers
Also make sure the paint is not lead -- as you shouldn't use a heat gun in that case. You'll see alligatoring texture if it is lead. Are you then staining to match the rest of the staircase?
HTML code is On
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Content Relevant URLs by vBSEO 3.2.0
