| Flooring Tile Ceramic, Marble, Terrazzo, Granite, Terracotta, Natural Stone, Etc. |  01-05-09, 10:19 PM | | Member | | Join Date: Jan 2002 Location: WA Posts: 157 | | | Should I tile the ceiling in my shower? I have low ceilings in my basement bathroom. The fan is just outside the shower. Currently the ceiling drywall in the shower is the same as the rest of the bathroom (i.e. not greenboard). Knowing that the direct water will be minimal, but will be mostly steam and spray, I am trying to decide between the following: A) Leave as is as. B) Coat with RedGaurd and repaint (maybe with water resitent paint). C) Tile over existing drywall (likely with a coat of RedGaurd). D) Cut out the drywall, install backer/cement board and tile. Option A is the easiest, but I would worry about rot. Option D is a real pain. At the moment, I am leaning toward option B. Here are some pics: Thanks! ~john |  01-06-09, 07:45 PM | | Member | | Join Date: May 2007 Location: Troy, MI Posts: 447 | | John, I disagree for the need of a CBU on the ceiling of this shower. You can do; A) Leave as is as. or C) Tile over existing drywall, with or without liquid membrane. If you simply paint it, I recommend using a paint made for this purpose. Use Perma-White by Zinsser. Mold Mildew Resistant Paint - PERMA-WHITE Mildew-Proof* Bathroom Paint Jaz |  01-06-09, 08:38 PM | | Member | | Join Date: Oct 2006 Location: sw sub chicago Posts: 465 | | | my shower is just green board painted with regular paint. no issues that i know of. but only 2 showers a day. chandler great looking shower. is that a water proof light ? |  01-07-09, 07:35 AM | | Member | | Join Date: Jan 2006 Location: New Jersey Posts: 2,616 | | | No need to change out the drywall and no reason to Redgard it. You can tile directly over it. Make sure the drywall is properly fastened to the ceiling joists. A few more screws is a good idea. Do to how low that ceiling is, I'd think twice about the paint option. That ceiling may receive a little more spray than you anticipate. |  01-07-09, 10:20 AM |  | Member | | Join Date: Dec 2008 Location: S.W. Ohio, in the boonies Posts: 15 | | | Once you get mold you'll have to dig deep and start over. Option "D" requires more work for sure. But would have longevity. Do it right the 1st time and sleep well. |  01-07-09, 06:30 PM |  | Member | | Join Date: Jul 2006 Location: Moore, Oklahoma Posts: 7,595 | | Quote: Originally Posted by Fox E Once you get mold you'll have to dig deep and start over. Option "D" requires more work for sure. But would have longevity. Do it right the 1st time and sleep well. | You typically do not have mold issues on the ceiling, or above the sprayer where water does not directly contact it. I've had drywall for my ceiling for ever and not a problem. I say, if the ceiling is already down, and you happen to have leftover CBU, then sure, why not, but I would not tear out a drywall ceiling just to install CBU. |  01-08-09, 06:56 PM |  | Member | | Join Date: Dec 2005 Location: Young Harris, Georgia USA Posts: 13,577 | | | Condo-owner, it is a fan/light combination, believe it or not! Regular square box installation in the joists with the cover. The inlets are above the light. Neat, huh? Expensive, yeah. |  01-09-09, 08:20 PM | | Member | | Join Date: Oct 2006 Location: sw sub chicago Posts: 465 | | Quote: Originally Posted by chandler Condo-owner, it is a fan/light combination, believe it or not! Regular square box installation in the joists with the cover. The inlets are above the light. Neat, huh? Expensive, yeah. | hmmm. i would be worried about shock and rust. my master has that type. but not IN the shower. | | Thread Tools | | | | Display Modes | Linear Mode | Posting Rules | You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 04:21 AM. | Sign up for our FREE newsletter! Find Qualified Local Contractors Sponsored Ads |
