cancel
Go Back   DoItYourself.com Community Forums > Flooring and Floor Coverings Center > Flooring Tile
Flooring Tile Ceramic, Marble, Terrazzo, Granite, Terracotta, Natural Stone, Etc.
Thread Tools Display Modes
  #1 (permalink)
Old 01-05-09, 01:39 PM
Porcelain Tile Removal
I am remodeling my bathroom and I'm having trouble figuring out how to remove the existing 4 X 4 porcelain tiles on the floor which are afixed directly to the plywood subfloor. The townhome was built in 1994 so I'm assuming that they've used a newer type of adhesive. I've managed to remove a 3 foot square section but that took me all day using a cold chisel and hammer but there has to be another, more effective method of removal out there. I've tried breaking the tiles from the top however these things are pretty tough and won't break. As I stated before the hammer and chisel method doesn't work very well either. A Air Hammer/Chisel would be out of the question due to the noise and proximity to my neighbors. Any suggestions? Could I tear off the subfloor while leaving the tiles glued down and then just replace the subfloor? Thanks in advace!
  #2 (permalink)
Old 01-05-09, 03:23 PM
HotinOKC's Avatar
It may end up being faster to pull up the entire subfloor with the tile still mostly attached.
Just remember not to fall through the middle of the joists and into the basement, safety first.
Also, who gives a hoot what your neighbors think as long as you are doing it during the daytime.
You're remodeling will boost their home values too....
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
