cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Fireplaces, Heating Stoves, Flues and Chimneys
Fireplaces, Heating Stoves, Flues and Chimneys Wood-Pellet-Artificial, Propane & Natural Gas
Thread Tools Display Modes
  #1 (permalink)
Old 12-23-07, 01:46 PM
Englander Pellet Stove Auger Motor
Hello,
I have an Englander 25-PDVC pellet stove. I've been having problems with the lower auger motor running hot. It seems like the lower motor has always ran hot since the unit was brand new. It has finally got to the point that the motor was loosing power. I ordered a replacement motor, but to try to keep the stove going until the new motor gets here I switched my auger motors around.
During a typical burn, the lower motor pretty much runs constantly, and the upper motor only runs a few seconds out of every minute. So the upper motor has far less use on it. Plus, in switching them around, it gives the wimpy motor that was originally on the bottom a much easier job to do.
Now that I have them switched the stove is burning as normal. And, once again, the lower motor is right on the edge of being to hot to touch. Is this normal? Has anyone successfully put a beefier motor in the lower spot?
The motors it has now are:
Merkle Korff Industries # 4515UI-063
This is a 1 r.p.m. 115 VAC gear reduction unit.
Thanks for your help!
  #2 (permalink)
Old 12-24-07, 10:31 PM
Quote:
Originally Posted by ___Brandon View Post
Hello,
The lower motor is in constant motion. But really shouldn't be that hot. Switching them is a good move as the upper motor only runs according to the pellet feed rate you have it set on.
Generally, the lower motor is the 1st to go but (again) generally after about 5 years. A premature failure is almost always due to the lack of proper cleaning of the lower auger tube. After each use clean the build-up of carbon towards the end of the tube.
When you get the new motor, hand spin the auger blade before installing the motor to make sure its properly aligned. It should spin very easily. Also I have seen nearly frozen auger bearings causing the motor to fail.
BB
  #3 (permalink)
Old 12-06-08, 06:27 AM
Englander 25-PDVC
I have this model as well. I have the same issue and took the same steps you have.and have ordered a new motor for the burner feed. The buildup of carbon on the end of the auger seemed to kill the motor and slow it down. I am planning the use a brake hone to clean our the carbon on the feed tube once the motor arrives and assemble. I was hoping to find a coating I could spray on the auger and feed tube to minimize the buildup. I get less than 24 hours before the auger is fouled to point it binds. I know other people who are using the same pellets and not having this issue. It must the stove design. I will advise on my fix.
http://img.photobucket.com/albums/v6...ghting0056.gif
  #4 (permalink)
Old 12-07-08, 07:13 AM
Augar Motors
My 25 PDVC is only a few months old and the top auger motor went out yesterday. I was on hold for an hour before a rep. took my call. After switching the motor wires and banging on the motor bearing with a hammer as he requested, they are going to sent me another under warranty. ( it sells for $140.00) I noticed the other motor was very hot also but the rep. didn't seem to think it was a problem. Their 3-5 days shipping is BS for people that use the stove as their only heat source. He told me there are no other parts retailers around.
  #5 (permalink)
Old 12-11-08, 03:20 PM
received replacement motor yesterday. seems to be OK. Its made by a different company then the OEM motor.I noticed what seems to be a little fan on the top of it. The bottom motor still gets hot while the new motor for the top auger runs cool.
  #6 (permalink)
Old 12-15-08, 02:20 PM
The flame that burns inside
The other end of that auger motor lives in hot flame, this is why it gets so hot. The metal is transfering the heat all the way back. no need to replace due to heat just once they stop moving. But i do need parts for my auger motor, Please reply if any one would like to sell there old motor. Thanks Al
  #7 (permalink)
Old 12-15-08, 03:27 PM
Quote:
My old motor was under warranty so I had to send it back. here is a link to the company that made it. perhaps you can get parts for it.
good luck
Merkle-Korff Industries
  #8 (permalink)
Old 02-01-09, 09:19 AM
Can you post the part number of the replacement motor, It sounds like it is a better motor for this application.
Thank You!
  #9 (permalink)
Old 02-01-09, 02:06 PM
Quote:
Thank You!
From the photo it looks like part number B16125AU1 here is a photo.
Here is their website.
Pellet Stoves, Corn Stoves, Gas, Multi-fuel and Wood Stoves by England's Stove Works (R)
  #10 (permalink)
Old 02-16-09, 06:08 PM
Thumbs up Englander Pellet Stove Auger Motor
Here's a link and pic. to a more beefy motor that is Made in USA:
PelletStoveParts.com: Product Display
  #11 (permalink)
Old 02-16-09, 06:44 PM
"The cost of parts that we manufacture are typically 15 - 60% less than OEM parts. By and large, the quality of our parts are as good as OEM, and in many cases superior. Most of our electric motors and blowers are identical to the OEM parts that they replace. "
PelletStoveParts.com: About Us
They are not saying where they are made and they admit that most are identical to OEM parts.
That motor pictured is about the same price as Englander gets.
It may be a good place to get parts, but I have a problem with any company that trashes some other company to get business. Just my 2 cents.
  #12 (permalink)
Old 02-25-09, 07:42 PM
My motor was Made in USA and it was slightly bigger than the original.
You must be reading something that I did not see. I did not read any trashing of other companies at all!
This is not trashing anyone: "The cost of parts that we manufacture are typically 15 - 60% less than OEM parts. By and large, the quality of our parts are as good as OEM, and in many cases superior. Most of our electric motors and blowers are identical to the OEM parts that they replace. "
  #13 (permalink)
Old 03-02-09, 11:14 AM
ww granger part number
does anyone have a part number for the same motor from wwgranger? Thanks, Joe
  #14 (permalink)
Old 03-02-09, 05:13 PM
Quote:
This may be the part. The rpm's on the oem are 1.0, the granger motor is 2.0.
I would call them to get more info
Please let us know how you make out
Power Transmission > Gearmotors > Gearmotors > Gearmotor,2 RPM,Torque 135,120VAC,Open : Grainger Industrial Supply
If you click on gearmotors near the page top you can search by rpm's horsepower etc; and you will find three more motors made by Dayton that might work. The price is much cheaper than oem motors.
  #15 (permalink)
Old 03-02-09, 09:51 PM
ww granger part ##
I ordered a 1LGN2 from Granger this afternoon. Should get it in 2 days. Will post how it goes.
  #16 (permalink)
Old 03-09-09, 07:42 PM
auger gearmotor
Tried 2 grainger gear motors. one with 100 inch lb of tork the other with 130 inch lbs of tork. Had to back up and order unit from the mfg. It works. only 10 ****s more than grainger unit that did not work
  #17 (permalink)
Old 04-04-09, 09:49 AM
does anyone know if these auger motors have a warranty on them? I have replaced mine twice in the last 2 years, and I keep mine extremely clean, doing a thorough cleaning about once a week! This is frustrating!
  #18 (permalink)
Old 04-04-09, 11:20 AM
Quote:
When you replace the motor are you turning the auger by hand to make sure it turns easy?
Just curious where you are getting the motors from?
The mfg. guarantees the original motor for one year.
I looked on the Englander website and they give no warranty info for replacement parts. My friend has had his stove 2 years without replacing anything.
I emailed them, asked for warranty info for replacement parts. Will post their answer here when I get it.
  #19 (permalink)
Old 04-04-09, 01:23 PM
Thanks for responding so quickly! I got the parts from the Englander Stove website, and once while talking to the rep on the phone. I do check them for easy movement, and they were fine. I chip away the carbon whenever I see a little bit of build up. I'm fanatical about it. Any information you could get would be most helpful! Thanks again!
  #20 (permalink)
Old 04-06-09, 05:50 PM
> Hello, I own a 25pdvc stove. If I purchase replacement parts
> example: a auger motor, from you. What is the warranty time frame that
> comes with it.
> thanks
> Philip
it would be 1 year.
This is the email question and reply I received from Englander stove today.
If your part is less than a year old I would give them a call ASAP
  #21 (permalink)
Old 04-17-09, 09:31 AM
auger motor problems
Just a word of advice concerniing these motors. If you remove the motor, you will find that the actual drive motor and stator are held onto the aluminium housing by 4 TORX screws. Remove these. Pull out the stator and remove the coil. You will see that the stator has a small worm gear ground into the end. Make sure it is not worn out.Then turn the aluminium body over and remove the 6 torx sdrews in this side. GENTLY tap on the 3/8" shaft and the unit will seperate in half. You will see globs of a clear grease which appears to be Petrolium Jelly inside. Visually inspect the gears for missing teeth or metal shavings. If everything looks OK, re-install the motor coil and stator and try gently rotating the stator by hand. You can hold the assembly together with your hand for this. If the gears all turn, but some grease around the shaft and re-assemble the entire unit, snugging the bolts up equally. You can test it by attaching an old power cord to the two prongs where the incoming power attaches. See if the motor turns. (be careful not to touch the live leads. Put some electrical tape around them.) Chances are your motor will operate OK, and the unit will turn.
There is a design flaw in these motors. The drive worm gear on the end of the stator is only held in place by a copper sleeve. If the least thing jams the auger, it causes the worm gear on the stator to misalign with the gear inside the aluminium gearbox. Then the motor will not turn.
If your motor is totally burned out, you can try a Dayton AC Parallel Shaft Shaded Pole Gear Motor, Cat. # 1LNG2, 1 RPM 100 in. lbs. of torque that looks identical to their motor. It costs $89.00 and can be found at :
Dayton Shaded Pole Gear Motors
Hope this helps!
PS: I've fixed mine twice like this.
  #22 (permalink)
Old 04-17-09, 06:31 PM
hfarrington, thanks much for the info. I had a motor replaced under warranty after only a month. I have two friends with the same stove that just finished there second winter without any problems. After my motor replacement I started using a surge protector.
  #23 (permalink)
Old 10-24-09, 12:34 AM
mid-michigan
I've replaced my auger motor once in 5 years, I chip the carbon off the auger everyday with a hammer and screwdriver, it builds up fast. A dremel moto tool also works, just make sure you have the ash vac running while using it. It would be nice to find a lower cost replacement motor $140.00 seems on the high side.
25pdvc decent stove for the price but alot of work compared to other pellet stoves on the market, a ash pan would be a plus.
It seems there design of the 25pdvc has not changed in atleast 5 years or so. A better igniter would also improve the stove, I crack the door open when starting it and use a propane torch to light it, its a lot faster and less smoke.
  #24 (permalink)
Old 10-24-09, 05:14 PM
I don't get much carbon on my auger, I haven't cleaned it off yet. The 25pdvc does require a little more work, I regret not having the larger pellet storage area that holds a full bag of pellets.
I use the propane torch also and I use a scraper to clean off the area where the igniter lights up. I have seen starter gel for sale that you put on a few pellets you plant inside the stove at startup.
I found a few motors for sale, but I don't know much about electric so I am not sure if these are the right fit.
The Granger and Dayton motors seems like a good buy.
Gearmotor,2 RPM,Torque 135,120VAC,Open - Gearmotors - Gearmotors - Power Transmission : Grainger Industrial Supply
  #25 (permalink)
Old 11-03-09, 05:04 PM
Well it is the second year and the motors are slowing. I did the cleaning per the above blog but it seemed to do very little improvement. One of the motors died within a week of installing it. Englander sent me another. They are a very cheap Korean motors. I am planning to replace the blower and convection motors this year nd I am hoping it will make a difference.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
